stock cam lift
- steell
Re: stock cam lift
07 May 2008 04:50 - 07 May 2008 05:05
Just keep in mind that pic is showing the differences between 750 Turbo cams and other cams (including Lorcan's reground GPz750 NA cams). The 365 and 395 cams discussed in this thread would kill the power on a Turbo, the stock GPz750 Turbo cams are the same as the KZ650 cams. Interesting that the Turbo and KZ650 use the same cams, but the Turbo (with three simple mods) puts out over twice the hp of a KZ650
Turbo bikes are a different kettle of fish.
The ZX A1 cams are stock GPz750
ZX 1E is GPz750 Turbo
Z 750 is KZ750
Yoshi cams are .400" lift at .010", or .360" lift at .050", probably comparable to the 365 cams discussed above (don't have a timing chart for the 365's so I'm guessing).
Notice the blue lines at the top that form a pie shape? The wider that is the higher the motor has to be wound to produce power.
Z 750 is KZ750
Last edit: 07 May 2008 05:05 by steell.
- vach
Re: stock cam lift
13 May 2008 11:30
Does anyone know the stock lift of a Kz1000? Any year..
1979 kz650 B. Chicago, Illinois
- steell
Re: stock cam lift
13 May 2008 19:40
If you go to Megacycle or Web Cams websites and look up the cams for the appropriate motor, one (or both) of them will have the stock cam specs listed at the bottom.
