GPZ1100B2 Oil pressure switch
- jcote75
16 Apr 2008 11:49
Hi,
Can someone tell me where is located the oil pressure switch on a 1982 gpz with fuel injection.
The wiring diagram shows one somewhere but it's located like a kz1000r where the oil cooler connect.
Thanks for your help
- tuxedotito
Re: GPZ1100B2 Oil pressure switch
16 Apr 2008 12:14
jcote75 wrote:
You have answered your own question correctly:cheer:! The switch is the white plastic piece that threads into the oil cooler bypass/connector. It goes in the big threaded hole in the picture. The picture is of a GPz1100 bypass so yours should look the same. Hope this helps.
Regards.
Hi,
Regards.
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- jcote75
16 Apr 2008 12:32
That is exactly what I got a my kz1100r.
But on the GPZ, the pressure switch is not on the bypass connector................
- jcote75
- tuxedotito
16 Apr 2008 12:50
jcote75 wrote:
Don't know what to say to that...try the Kawasaki Parts lookup
kawasaki.com/DefaultFrame.aspx?strConten.../VICHOOSEVEHICLE.ASP
You could maybe drill and tap a hole and use an aftermarket sensor??
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- jcote75
16 Apr 2008 13:11
I think I found it. Look like it is on the oil pan. Will check tonight on my GPZ motor now that I know where to look.
I'm installing the oil cooler on the kz1000j, so I will need to swap oil pan if I want the oil pressure switch to work and probalby extend the wiring.
Thanks for your help!
- jcote75
Last edit: 16 Apr 2008 13:13 by jcote75.
- tuxedotito
16 Apr 2008 13:16
jcote75 wrote:
I'm fairly certain that the oil pan sensor is for "oil level" and not pressure. I could of course be wrong...good luck with it either way!
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- jcote75
16 Apr 2008 13:20
Your correct............. for the oil level...........so where is the pressure switch!!!!!
- tuxedotito
16 Apr 2008 13:31
jcote75 wrote:
Why not just find and use another bypass, like the one I pictured for you, that utilizes the screw-in type pressure switch like the 1100R and 1000J; it will most certainly fit, and your problem is solved??
Just a thought...
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- jcote75
16 Apr 2008 13:35
I already got the pressure switch form the kz1000j that I could fit on the gpz1100 oil connector.
I was just a little anxious to do permanent damage to the gpz part by trying to drill a hole and doing new tread for the pressure switch.
Did someone did this before with success?
- RonKZ650
16 Apr 2008 13:38
Look at the diagram "crankcase" and it shows the switch right where tuxodito shows, right on top of the adapter thing. The strange thing is they show 2 different possibles, one adapter than has the switch and one that does not. It may be that it only has the level, and no pressure switch on some of the GPZ1100? Strange.
