- Thank you received: 7
Dented oil filter!
- pyxen
10 Apr 2008 17:52 #205545
by pyxen
- pyxen
10 Apr 2008 17:53 - 10 Apr 2008 17:53 #205548
by pyxen
Last edit: 10 Apr 2008 17:53 by pyxen.
- BSKZ650
- Thank you received: 14
11 Apr 2008 05:17 #205650
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Dented oil filter!
Thats ugly,, how bad is the cyl,, looks like it will need to go to oversize to me,,,,, big bore here we come
- pyxen
11 Apr 2008 06:03 - 11 Apr 2008 08:20 #205671
by pyxen
84 KZ550-F2 LTD
93 ZR550-B4
Replied by pyxen on topic Dented oil filter!
On that note.. can I do the one, or should I do all 4?
What are my best options, and what should I expect through the process?
Oh..and the grooves in the cylinder are bad..around .5-1mm in depth at the top.
84 KZ550-F2 LTD
93 ZR550-B4
Last edit: 11 Apr 2008 08:20 by pyxen.
- BSKZ650
11 Apr 2008 08:21 #205697
by BSKZ650
Do all four,, and in addition you need to get the head checked,, I think you will find some metal on the valves also,, which will require a valve job on the head..
Goes from bad to worse:blush: :blush:
- pyxen
11 Apr 2008 11:07 #205752
by pyxen
84 KZ550-F2 LTD
93 ZR550-B4
Well I've been speaking to APE already, so we'll see what happens.. I'm going to investigate a high-performance machinist in my area first, and then if that pans out, figure out if I want to invest in getting the engine back in order, or just part it out and find myself a nice affordable Kawi Ninja 650R.
I just wanna ride!
I just wanna ride!
84 KZ550-F2 LTD
93 ZR550-B4
- Locozuna
11 Apr 2008 15:16 #205806
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Dented oil filter!
Bummer! I also found it odd that the "fence" was solid as I have only seen perforated ones. Then again I didn't know any ere supposed to go on top of the filter. Just when you think you seen/know it all!:woohoo:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- pyxen
06 Mar 2009 10:54 #270046
by pyxen
84 KZ550-F2 LTD
93 ZR550-B4
Hey..Just bringing this puppy back up top to say - de-winterize properly, and I'm gonna be rebuilding it this year, so all design ideas can be sent along.
If I decide to bob it, or at least chop the frame back a bit, is it enough to get a welder to put a support piece between the frame just behind the suspension mounts, midway through the gussets, or should I have him do it at the back of the gussets?
84 KZ550-F2 LTD
93 ZR550-B4
- steveskz
08 Mar 2009 19:18 - 08 Mar 2009 20:18 #270483
by steveskz
Replied by steveskz on topic Dented oil filter!
I have a KZ100st e1 I know my oil filter spring is missing the washer, is this washer what they call the spring seat? I'm not sure how important that part is but my bike is missing it?
Last edit: 08 Mar 2009 20:18 by steveskz.
