- Thank you received: 2829
Water cooled KZ900?
H2O KZ
- bountyhunter
- Thank you received: 337
The machine shop that did my head was the service center for the KZ1000 police bikes of all the local cities and the guy told me on average they ran less than about 20k miles before needing valve jobs. Got to think that's heat related.
- Bad Kaw
- Flying Squirell
- Thank you received: 13
Not trying to start a fight here, but water cooling brings ailments all it's own; not superior, not inferior...simply different.
Actually, no. The fact that later model motorcycles need their valves adjusted less frequently is directly related to design, tolerances, and specifications. This has nothing to do with how a motor is cooled. Consider: any late model sport-bike that needs any valve adjustment, mid-80s Honda 650 Nighthawk that needs no valve adjustment. The Nighthawk isn't 'better', it just has hydraulically adjusted valves as designed by the engineers...and it's air-cooled.
Also, don't think that a liquid cooled motor necessarily has internal motor temperatures that are lower than air-cooled motors. RC51s regularly run in excess of 220+ degrees! Nothing in my garage runs that hot...on purpose:lol: . Yet, there is nothing wrong with the RC running that hot (other than operator discomfort) b/c the designers built it that way.
Most motor oils are designed to take some impressive heat. The thing that performance motorcycle oils have to worry about the most is "shear", which is extreme in most motorcycle engines b/c the crank-shaft oil is shared with the transmission oil, which is shared with the clutch oil. These are three ares where shear is extreme and an oil can be broken down rapidly. These three areas are not directly affected by liquid cooling.
In short, air-cooled motors are not inferior to liquid-cooled motors. However, technology marches on and later model designs do achieve their goals more effeciently than designs of the past...they'd better, or we're going backwards.
-KR
PS> Not trying to offend...
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
- bountyhunter
I didn't do nearly as well the second time: the valve seals failed after about 15k miles and I had to tear it down again.
I just don't see air cooled engines doing what I see some cars do: going 150k without ever opening the engine at all except for maintenance.
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- steell
IIRC, Ronkz650 hit ~160k miles on his KZ650 without opening the motor up.
In 1981 I helped a friend swap motors on his 75 GL1000 because it was starting to burn a little oil, it only had 250k miles on it
- RonKZ650
- Thank you received: 240
- Z1R rider
- Thank you received: 5
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
- flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
- fastestz1
i have owned sum older volkswagon beetles that were heavily suped up one was turbo'd all air cooled all went better than 100k before i sold them in great running conditionThe machine shop guy did not tell me the KZ1000's needed valve adjustments every 20k, he said they needed the heads pulled and have the valves re done that often. When I told him my KZ-750 twin had made it about 45k on the original valves, he was stunned. he had never heard of a kawi going that long in city riding without needing to tear the head down. he thought mine was going in for it's second valve job by then.
- Bluemeanie
- Thank you received: 14
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
