Porting Kawasaki cylinder heads
  • kawsakiman
  • kawsakiman's Avatar
Re: Porting Kawasaki cylinder heads
11 Mar 2008 07:41
#199516
kzwolfsr wrote:
I would like to see what a ported head looks like
here is a ported 650 head.
  • kawsakiman
11 Mar 2008 07:42 - 11 Mar 2008 07:45
#199517
Last edit: 11 Mar 2008 07:45 by kawsakiman. Reason: picture was to large
  • kzwolfsr
  • kzwolfsr's Avatar
11 Mar 2008 11:59
#199549
thank you Kman. I always hear about this but no one never showed me what they looked like. Now I know!
Original man of the Caribbean
  • kawsakiman
11 Mar 2008 12:54 - 11 Mar 2008 12:58
#199563
here is the difference.
stock on bottom, ported on top.
like plummen said, a ported head alone could hurt more then it helps.
these motors respond better to cams
Last edit: 11 Mar 2008 12:58 by kawsakiman. Reason: picture would not fit.
  • larrycavan
  • larrycavan's Avatar
12 Mar 2008 06:20
#199695
Ituen wrote:
Where's the best place to have Kawasaki cylinder heads ported? Who's a Kawasaki motorcycle head guru?
Do whatever you like with the head but there are questions that need to be asked by whoever is porting it. If they're not asking questions, think twice.
Two ports cut to the same size don't always flow the same amount of air.
Velocity is important. You can also have too much velocity and the bike will not perform.
Then you have the big valve vs stock valve scenario and believe me. Most guys do not need the 37.5 intake valves that are so popular to install by some shops.
If you want flow data on the KZ head, here's some www.flowbenchtech.com/porting/CRH/kz-data.htm
  • Ituen
  • Ituen's Avatar Topic Author
  • Rider
12 Mar 2008 12:59
#199756
PLUMMEN wrote:
what else is done to motor?lots of other stops before porting a head
I had the carbs rejetted and a V&H exhaust put on the bike. What else should I do before porting the head?
1982 KZ750 E
Kawasaki Rider
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
12 Mar 2008 13:51
#199767
performance camshafts.head porting alone generally does not net any noticeable gains.it needs to be used in conjunction with carbs,cams,exhaust.
