should i degree cams milled head 25 thous
  • odl666
  • odl666's Avatar Topic Author
16 Jan 2008 15:45
#189618
Does any one think i will need to degree the cams for only taking 25 thous off the head. I am putting gpz 750 cams on a kz 650.
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
  • hannah1
  • hannah1's Avatar
Re: should i degree cams milled head 25 thous
16 Jan 2008 16:18
#189629
After you did all that other work it would be nice to know that your cam timing is optimum .
  • odl666
16 Jan 2008 16:21
#189630
I dont know were to buy slotted sprockets for the gpz 750 cams
1979 gs750e
  • PLUMMEN
  • PLUMMEN's Avatar
16 Jan 2008 18:54
#189647
:P
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
16 Jan 2008 19:17
#189652
The head on my 1000 was milled about .030" and when I degreed the cams they really needed adjusting. Now, I never had them degreed before the milling, but I was told my the builder to definitely degree them since it was milled.
Like wire..uh I mean plummen said, you can modify your stock sprockets with a little old fashioned elbow grease;)
The Kaw List:
  • kawsakiman
  • kawsakiman's Avatar
16 Jan 2008 20:03
#189656
one word answer
yes
  • steell
  • steell's Avatar
16 Jan 2008 20:58
#189660
kawsakiman wrote:
one word answer
yes
Any more questions??
You don't have to elongate the holes very far, .020" (or .5mm) should be enough.
  • odl666
16 Jan 2008 22:04
#189663
sounds easy enough i thought i had read some forumns on that rat tail file earlier. thanks
1979 gs750e
  • APE Jay
  • APE Jay's Avatar
16 Jan 2008 22:51
#189667
Milling the head or block retards the cams.
Jay
  • trippivot
  • trippivot's Avatar
17 Jan 2008 11:27
#189743
good reason to buy more tools and a book!!
  • larrycavan
  • larrycavan's Avatar
17 Jan 2008 15:44
#189801
kawsakiman wrote:
one word answer
yes
Second that motion..
  • modprod
  • modprod's Avatar
19 Jan 2008 17:32
#190138
Actually it can help to "degree" even a stock setup if you want the best tune you can get. You really don't know where the cams "actually" are, until you put on the wheel and indicator. Even all stock can vary a few degrees and is often the reason why one complete stocker always seems to run better than another otherwise complete stocker.
