What is your dream motor?
- Invicta 39
- zippy
1. Falicon welded, balanced and magnafluxed crank
2. Manley steel crank main bearing brace and heavy duty bearing bolt kit
3. Heavy duty crank case bolt kit
4. Chrome oil pan with special oil flow gate
5. Oil windage tray
6. Custom fabricated polished oil breather with multiple outlets with braided stainless steel lines
7. Polished alternator cover
8. PMFR clutch release system
9. Falicon undercut transmission gears
10. Over shift limiter bushing
11. APE cam chain tensioner
12. Complete stainless steel allen bolt kit for all covers
Cylinder Block
1. MTC big block - copper O- ringed
2. MTC 1500cc 8.5:1 compression ratio blower pistons
3. MTC heavy duty blower wrist pins
4. Teflon wrist pin buttons
5. MTC heavy duty cylinder studs
6. FBG heavy duty cylinder stud nuts
Cylinder head
1. Blower ported head by Orient Express
2. Bronze valve guides
3. Heavy duty race valve springs
4. Teflon valve guide seals
5. Titanium valve spring retainers
6. MTC shim under buckets
7. Oversize Manley stainless steel valves
8. Slotted cam sprockets
9. Stock cams installed with 110 deg. Intake and 112 deg. exaust lobe centers - extra race cams included
10. Heavy duty cam chain
11. Manley aluminum cam cap end plugs
Clutch
1. Barnett heavy duty clutch plates
2. Barnett heavy duty clutch springs
3. MTC timkin bearing clutch pusher
Ignition and electral
1. Very trick Bill Hahn BHP H.E.I. blower ignition with special boost retard that senses blower manifold pressure
2. Heavy duty race plug wires
3. Chromed cover
4. Fast by Gast battery
Supercharger
1. Magnuson blower with teflon seals on lobes
2. Magnuson blower drive from clutch w/pullys for 8 lbs and 20 lbs boost
3. Magnuson fuel pump drive off of blower for Hilborn fuel pump
Fuel Injection system
1. Hilborn fuel injection system - S- 24 throttle body - 2 7/8 bore with metering valve
2. Hilborn PG 150 fuel pump
3. Hilborn velocity stack
4. Kinsler adjustable dial - a - jet system
5. Kinsler adjustable high speed precision bypass valve
6. Tons of Hilborn and Kinsler fual flow pills
7. Braided stainless steel fuel lines
Post edited by: zippy, at: 2007/09/19 01:32
Post edited by: zippy, at: 2007/09/19 01:34
- zippy
- nads.com
- Thank you received: 20
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- tjettim
and 33 smooth bores is the best power to
durability setup.
- modprod
I would like to rebuild an engine for my 76 900. I will not be racing it but would like it to have plenty guts. I have looked at APE and they have a lot of stuff their, but I would like to hear your input on what would make a great motor: eg. Crank, rods, pistons, head, valve stuff, etc, etc. I do not have unlimited funds, but I can take some time to do this so I can piece it as I go. Any info on what parts to use and what needs to be done to the parts is welcomed.
If your on a tight budget, it would be hard to beat an APE 1015 kit. With the machine work and misc, probably about $1200+ kzzone.com/kits.html
My "dream" motor is:
72mm bore custom pistons
73mm stroker billet roller crank for 1230cc
480 460 cams
big "titanium" valve head, maybe like 38.5 x 32
5speed "overiding" transmission
probably about $15000+
Very possible "dream" motor: 72mm/1075 that runs 8s on "motor only" at 575#
Post edited by: modprod, at: 2007/09/19 09:26
- tjettim
cylinder and head with the 45mm intakes
and 38mm exhausts.Of course you could buy
a new ZX14 for less money than the motor
would cost to build.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
Skyman.
Skyman.
SKYMAN!!!! WAKE UP!!!!!
Whoa! What a dream! :pinch:
Post edited by: Skyman, at: 2007/09/19 14:00
West Linn, OR
- 810gpz750
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
- Bluemeanie
- Thank you received: 14
