1198 woes
- tjettim
Re: 1198 woes
06 Sep 2007 03:12
I had thought of trying two base gaskets.
I think OEM kz1000 gaskets are .030".My
cylinder and head have been resurfaced also.
I am not sure what to do next though.
- mark1122
- Keep twisting it
Re: 1198 woes
06 Sep 2007 04:54
i posted about useing 2 base gaskets and the response was not to.aparently they tend to squees out.
maybe u could try to have the head oringed.i had a high compression 2 stroker and it was oringed and had a rubber oring in it. u said the head gasket u used had noe metal rings on top ,is that right? if not that is likly the problem. mine does.is yours a 1 peice or 2?did u fill the oil o ring groove with silicone?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BSKZ650
Re: 1198 woes
06 Sep 2007 06:08
I have used copper coat with great success, but if I have a leak that will not stop, then yamma bond seems to seal just about everything
77 ltd1000, current rider
76 kz900, just waiting
- tjettim
Re: 1198 woes
07 Sep 2007 06:31
The head gasket is one piece,metal rings
on bores only,not on oil galleries where
the oil leaks always start.Siliconed oring
groove.gaskasich on base gasket.The first time
I did the 1198 I did not use gaskasinch or
silicone and it imediantly leaked,I had to
take it all apart and put new gaskets in.Unless
a better gasket set comes along it is staying
the way it is untill I find a nice stock motor.
Then I will sell off the parts from this motor.
In the mean time,if I get enough money I am going
to do what I should have done in the first place
and buy a newer bike.I will still keep the KZ
though.With just a header and 29 smoothbores it
was fun and stone reliable.
