cylinder head bolts (not nuts)
  • BSKZ650
  • BSKZ650's Avatar
Re: cylinder head bolts (not nuts)
30 Aug 2007 04:59
#167320
I am still thinking torque wrench, but if not then has the motor poss been overheated sometime in its life so the bolts have become soft?
You might pm Duck, I think he worked out a way to test the wrenches using a vise, dont remember the details, but he has "proved" toruqe wrenches before.
one othe note, if you dont back off the torque wrench when you store them they will not be accurate
77 ltd1000, current rider
76 kz900, just waiting
  • wiredgeorge
  • wiredgeorge's Avatar
30 Aug 2007 05:59
#167330
I am not all that familiar with your engine... what bolts are we talking about? There are only two bolts on a 903/1015 cylinder head and these are 6mm bolts and torque is less than 6 ft/lbs as I recall. In order for a bolt to have a torque spec of over 20, it would have to be a 10 or 12mm bolt.
  • RonKZ650
  • RonKZ650's Avatar
30 Aug 2007 06:34
#167335
It's a 6mm 43mm long bolt. No doubt 18 ft/lb is way overboard on this size bolt.
  • steell
  • steell's Avatar
30 Aug 2007 07:06
#167339
Maximum torque for a 6mm grade 12.9 bolt is 12 ft lbs according to this Chart
  • cottoncandyninja
  • cottoncandyninja's Avatar Topic Author
30 Aug 2007 08:36
#167351
hey now guys, its a 8mm bolt. and i got a message from jeff telling me that he feels some of the oem kawasaki bolts are junk anyways. he suggests i go to the hardware store and get something with a higher grade for this stress. the bolts i bought from kawasaki arent even graded which really supports jeffs comments. it also makes alot of sense considering i stretched a brand new bolt last night in no time.
  • cottoncandyninja
30 Aug 2007 09:13
#167362
if i get a higher grade bolt and install it to that high torque, do you think ill have to worry about the threads stripping out? do you think kawasaki is really going ove board on this torque for an 8mm bolt?
  • MDawnz1
  • MDawnz1's Avatar
31 Aug 2007 19:56
#167659
Are you "SURE" it's not calling for in/lbs ?
That sounds like an awful lot if its the bolts I am thinking of .
1974 Z1a, still 903
