cam chain tensioner options?
- craigpuckett
Re: cam chain tensioner options?
23 Jan 2006 06:21
My instalation was on a J model motor with the hi-vo type camchain/slider ,on the kz style the instalation may be different but I wouldnt think so,if it rattles when you start the bike you know its to loose,here is a link to a how to I found on Jays site.
www.morrowmarsh.ca/concours/techpages/ca...tensioner-manual.htm
- guitargeek
06 Jul 2006 10:29
I've heard rumors that a cross-wedge tensioner can be converted to a manual tensioner. I've thunk and thunk on it, and can't see how.
Anybody have any input?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- kawtoy
06 Jul 2006 17:36
I have a homemade one on my 1000. It looks just like the APE version. Works fine. I can get as pic if you want.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- DesertWizardB1
06 Jul 2006 17:38
craigpuckett wrote:
I did that to mine. It's basically an extra lock to help keep the tensioner from slipping but you can also use it to put a little more tension on the chain if you think your spring is weak. Here is some pics:
users.adelphia.net/~lbilling/images/motorcycle/DSCF0340.JPG
users.adelphia.net/~lbilling/images/motorcycle/DSCF0343.JPG
Len
back before Jay brought out his tensioner,the trick used to be to drill a 6mm hole in the back of a 900 tensioner and use a bolt and a lock nut as a positive stop.
Jays is a better option IMHO.
Len
Len
77 KZ 1000 LTD Original Owner
- nads.com
06 Jul 2006 20:43
I would take the valve cover off any bike to set the tension with a manual tensioner. Its just not something to mess with guessing. If you get it too tight, the idler wheel will wear.
- Jack
07 Jul 2006 10:25
Nads has an excellent point. We've used APE manual tensioners on the dragbikes for years and years, an excellent product.
However,if you put too much tension on the chain you'll find the black rubber roller in a fine suspension in your engine oil.And nothing left of the roller but the steel insert in the middle -don't ask me how I know this...
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
