What is a mk2 engine?
- mark1122
- Keep twisting it
Re: What is a mk2 engine?
26 Jul 2007 21:42
do the mk11 cases bolt up to the kz frames without mods?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
27 Jul 2007 00:07
yep;)
- wiredgeorge
27 Jul 2007 04:29
I have a couple MKII engines and you can tell because they have a bevel gear hanging off the side rather than a countershaft sprocket bwhahaha
The shafty has a MKII engine but has a shaft... here is a pic during last rebuild. The engine would fit into any Z, KZ900 or KZ1000 (up to 80) frame if it had a chain drive.
- APE Jay
27 Jul 2007 16:59Please Log in or Create an account to join the conversation.
- wiredgeorge
28 Jul 2007 06:09
They are K&L supply cylinder head nuts and you are absolutely right... they work BAD... they are not quite as wide as the copper washers and those things sprang leaks on all four oil journals. They are gone and I put a set of OEM nuts on which are slightly larger diameter and stopped the leaks. I painted them black as they always look rusty and if you clean them up, the rust just comes back... will look into the APE nuts as I didn't know you sold them.
- APE Jay
28 Jul 2007 22:48
We have made these for years. Heat treated to outlast the KZ. Also taller than stock, so one can mill the head to the max, and not have the stud bottom out in the nut.
Jay
Jay
- Snakebyte
30 Jul 2007 04:49
I'll keep that in mind when I mill .030 off my gpz head.
