Big Bore starter.
  • Skyman
  • Skyman's Avatar
Re: Big Bore starter.
14 Jun 2008 11:58
#219985
Yep, it's amazing isn't it? What a differnce it makes. I thought the same thing when I made the change. Wow!
West Linn, OR
  • 77KZ650
  • 77KZ650's Avatar
28 Jun 2008 23:24
#222750
you could use a 24v starting circuit with the stock starter. on the zx12r when you start getting into big bore stroker motors they get very hard to turn over. i know a guy with a 1427 with over 16:1 compression ratio and his starts very easy with the stock starter using a 24v setup. when his bike was "only" a 1361 using the stock starter and 12v it was hard to start when hot....
07 MDP Rookie of the Year
