Possible/Worth to add a fan?
  • slickware
  • slickware's Avatar Topic Author
  • My bike is as old as I am
Re: Possible/Worth to add a fan?
11 Jun 2007 07:23
#148297
I would run a manual switch somewhere, because I'm competent enough to do that, but the idea of finding a fan plus a temp sensor switch is more electrical than I will ever be :)
1982 KZ1100 Spectre
Old. Shiny.
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
11 Jun 2007 07:28
#148300
www.muzzys.com/fans.cfm
muzzy makes aftermarket parts for big horsepower rockets.
I think he ment this aluminum fan...
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • slickware
11 Jun 2007 07:44
#148306
That site is showing a fan for the KZ1300... I wonder if that would be a good match for my KZ1100?
~A
1982 KZ1100 Spectre
Old. Shiny.
  • Muddy
  • Muddy's Avatar
11 Jun 2007 08:46
#148318
FZR 600 was yamaha's answer to Honda's 600 hurricane in the late eighties. It had the new "Genesis" head design and the Deltabox frame. They were made from 89-99 with little to no change. Years ago it was a decent 600 sport bike until Honda 600F2 came out. either way Yami made a ton of them and parts are cheap and plentiful.
I meant the Muzzy's aluminum fan. If you go with a sportbike style fan for the oil coller its probably gonna run close to the pipes. If you go with the Aluminum fan you won't take the chance of the fan blades melting. you'll still need the motor and housing from the original fan with the muzzy's unless they make a whole kit. I've just seen the fan itself ever. Plus the Muzzy's are a good bit more efficient from what I've heard. That said I still run the two stock fans on my TLR.
You'd def want a toggle switch on your handlebars to control the fan as you'll have no coolant temp switch. Alot of guys wire them manual anyways. My TLR fans don't come on to well over 225 degrees with the temp switch. Which is weel over the threshold for a toasted crotch.
Post edited by: Muddy, at: 2007/06/11 11:48
  • flht1997
  • flht1997's Avatar
11 Jun 2007 09:02
#148325
i did not think the FZR 600 had the Genesis head, it had the genesis design with the canted cylinders but no 5 valve, but hey i could be wrong, i thought you had to get to the fz750 and bigger to get that.
IMHO i think the oil cooler would provide more cooling than a fan pointing at the engine. and if you are desparate to put a fan i would then mount it to the oil cooler. :)
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • wireman
  • wireman's Avatar
11 Jun 2007 09:51
#148348
im going to mount a small puller fan in between the backbone tubes on my z1 to pull over top of motor when im sitting in traffic,im also going to mount an oil cooler down low;)
  • Nevco48
  • Nevco48's Avatar
11 Jun 2007 10:15
#148358
Or... just move to a place that doesn't have traffic.:whistle:
  • Makarth
  • Makarth's Avatar
11 Jun 2007 10:17
#148360
i bet a pc fan would work and they only run off of about 12 volts. I used to build my own gaming pc i remember i had fans in it that could move more then 120 CFM. im sure 2 of them would make a noticeable difference in standstill traffic. Some thing like these would do and they are cheap. www.dealtime.com/xPO-Vantec-80x80x38mm-V...-Pin-with-RPM-Sensor
i just looked up what cfm the transmission cooler for my truck would move and its only 400 cfm. So 112cfm has to be more then enough.
Post edited by: Makarth, at: 2007/06/11 13:21
1977 kz1000 - Megasquirt project @ 40% wiring, plenum, and exhaust<--(done!)
  • Muddy
  • Muddy's Avatar
11 Jun 2007 10:20
#148361
I'm pretty sure your right about the head. I meant the overall design canted so far forward.
Oil cooler is def a better option than fan alone. I was thinking both oil cooler and the fan for max cooling.
  • slickware
11 Jun 2007 11:07
#148378
I think I would want to do both oil cooler and fan(s).
How much work is installing an oil cooler? Will I have to take off more than the tank?
~A
1982 KZ1100 Spectre
Old. Shiny.
  • kawsakiman
  • kawsakiman's Avatar
11 Jun 2007 15:10
#148444
i like this idea
mostly wiremans hidden fan idea.
then i would not be so scared to run a higher compression engine in traffic.
i like the idea of a stealth setup.
got any pictures or diagrams of your idea?
i would like it to be functional but not a eyesore.
hell, if we do this right we can patent it and make some money!
:blink: :woohoo: :lol: :P :laugh: :ohmy: :whistle: :evil:
  • wireman
  • wireman's Avatar
11 Jun 2007 17:11
#148473
just a vision bouncing around my empty head!:P since im relocating my coils theres a lot of extra room in frame backbone area even with the extra bracing;)
