Low vacuum readings in carb sync
- tjettim
Re: Low vacuum readings in carb sync
11 Jun 2007 11:28
There are nine different ways to measure vacuum.
24cmhg = 9.4 inhg.I have new 10.5-1 pistons and
300 duration cams.1100 rpm is about as slow as it
will idle so I set them at about 10 inhg.If you
have a bad cylinder the gauge needle will probably
jump around alot.
jump around alot.
- BSKZ650
11 Jun 2007 11:54
why are you wanting to pull the head? check the cams and the valves, run a quick compression check.
just a thought, did you make sure all the gauges are reading equal, hook all of them to one source and see if they read the same
77 ltd1000, current rider
76 kz900, just waiting
- flht1997
11 Jun 2007 12:23
just did the sync on my 650, my reading were right around 10.5 in at 1500 rpms. i really do not know if the gauges are accurate and really do not care as long as they are even.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
11 Jun 2007 12:31
I also sync'd mine to about 10 on the guages.
West Linn, OR
- vach
11 Jun 2007 13:06
Alrighty thennnn! I meant the cylinder head to check the valve clearance and cams.. My bad.. Well, it looks like #2 and #4 @ 12 inhg(i think) look pretty good.. I'll try and match #1 that's @ 5 inhg and #3 that's @ 10 inhg to 2 and 4 and see how I come out.. Ahhh.. Closer and closer. It has been 8 long years since I've ridden my bike.. Owned it for 17 years.. I took it for a spin and man.... Do I miss it! I can't ride it back from Indiana until I get it safe and reliable though, so it seem like it's takin FOREVER.. Soon my pretty, soon..:blink:
1979 kz650 B. Chicago, Illinois
- BSKZ650
11 Jun 2007 13:37
flht1997 wrote:
aint no way its gonna run right with those H!#$@da gauges
- flht1997
11 Jun 2007 17:43
hey! those buggers were .99 on ebay and i could pick them up so no shipping, and the work real good on a kawi.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
89' BMW R100RT
06' KLR650
- vach
- vach
