piston honing
  • steell
  • steell's Avatar
Re: piston honing
07 Jun 2007 05:21
#147116
wiredgeorge wrote:
I am curious... how did you measure the cylinder bores using a digital caliper? You have to make six different measurements... at different depths and different angles to determine if the bores are out of round. Tee bore gauges are the only way I know to make this measurement. Anyway, good luck.
George, get yourself a digital bore gauge, it's a lot faster and easier, and more accurate as well (.0001-.0005 depending on model). More accurate because there are less measurements involved so less chance of making a mistake.
Here is an example of one model, but there are several others available.
The one pictured (along with others) is available at www.goodson.com/ the engine builders dream site :D
Post edited by: steell, at: 2007/06/07 08:25
