Flash Rush in tank. Help
- cuddies
Anyways, I do have one slight problem. In the article it says wash it out thoroughly, and then attach a dryer to it and dry all the water out. Well, I can't get it dry before it freakin' flash rusts all over. I did put in the Naval Jelly, but as soon as I wash that out with water, it rusts almost instantly. Before I can get it dry, it is already rusted. Is there something I can do. I will put in another batch of Muriatic Acid and clean out the present surface rust, but when I wash that out and go to dry, I............?
- kawsakiman
- Thank you received: 6
drain tank.
fill with simple green.
then boiling water.
let set overnight.
drain tank and try to dry as best as you can.
put in two cups of vegetable oil and swish around, covering the whole inside. then drain it again.
when you re-install it the oil will be so minute that it should not effect it.
( fill to the top with gas first of course)
always worked for me.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
but i dont know if you could get it onto the metal before it rusted. I think that a little light flash rust will not really hurt much when you throw the tank on the bike.
Just change the fule filter after a tank or two of gas.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- OKC_Kent
- Thank you received: 20
You could always skip the hair drying part and rinse with water, then maybe dri-gas treatment to absorb the water, and a rinse with some light oil. that would probably keep it from rusting.
kawasakiman, sounds like your making a salad with greens and oil!:woohoo: :lol: :lol:
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- arobsum
- Thank you received: 10
- cuddies
BTW, using the vegatable oil...what would that do? I thought oil and water don't mix..
- KZQ
- Administrator
- Thank you received: 1413
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- KZQ
- Administrator
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- cuddies
Just reread you post. Did you follow the article I posted here: kzrider.com/content/view/22/11/ ?
KZCSI
Yup yup. I used that exactly. It worked perfect.
But after I flush out the Naval Jelly THOROUGHLY, it rusts a bit before I can get it dry.
P.S. Sorry for posting in the wrong forum.
- JMKZHI
- Thank you received: 48
- Thank you received: 2098
WD40 (WD stands for Water Displacement) is available in liquid form. Have seen it in gallon size, but unsure about smaller size.
Immediately after water rinse, pour in some WD40 and shake-slosh it all around inside the tank. It should displace and help remove the water. And any spillage won't harm the paint. Should also leave minimal protective coating until filled with gasoline.
Suppose you could rinse-flush first with common rubbing alcohol (a bottle full) to remove most of the water residue before the WD40 treatment.
So the sequence would be: muratic > phosphoric > water > alcohol > WD40 > gasoline > rust-free happiness.
Good Luck!
- Bad Kaw
- Flying Squirell
- Thank you received: 13
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
