can this be fixed reasonably or i am sol
- udder
23 May 2007 10:41 #142780
by udder
can this be fixed reasonably or i am sol was created by udder
ok had problem with idle and with the help of others went through some things to correct. sprayed around boots and found i had a leak letting air in. well i took the boots off to inspect and one of the inner boots came off well with a little more than the boot. the bottom bolt ear for the carb boot came off with the boot. see pics. will dry fit right back into place but can it be jb welded??? what are my options.:sick: :sick: :sick:
- udder
23 May 2007 10:43 #142782
by udder
Replied by udder on topic can this be fixed reasonably or i am sol
shoot pics too big im working on it
[img][img SIZE=550]http://i211.photobucket.com/albums/bb207/shag9499/DSC01138.jpg[/img]
[img]
Post edited by: udder, at: 2007/05/23 14:03
Post edited by: udder, at: 2007/05/23 14:04
[img]
- udder
23 May 2007 10:49 #142787
by udder
try again
[img][img SIZE=550]http://i211.photobucket.com/albums/bb207/shag9499/DSC01139.jpg[/img]
Post edited by: udder, at: 2007/05/23 13:50
Post edited by: udder, at: 2007/05/23 14:08
- mrbreeze
23 May 2007 11:20 #142794
by mrbreeze
Replied by mrbreeze on topic can this be fixed reasonably or i am sol
I think your SOL… Sorry
You might get away with JB Weld for a while, but it will eventually give up when you least need it to.
There are a lot of cool adhesives on the market now tho.
Your best bet would be to use the EBay link and search for kz1000 boots. There are some nice ones with a current bid of $6.95 with 1 day and 7 hours left. Of course they will go up but you could get lucky.
kzrider.com/component/option,com_joomlab...w/id,133801/catid,8/
- Thank you received: 2098
23 May 2007 11:38 #142799
by Patton
Replied by Patton on topic can this be fixed reasonably or i am sol
Another source, if needed:
Z1E lists set of 4 carb holders for $63.13.
Z1E Carb Holders
Post edited by: Patton, at: 2007/05/23 14:39
Z1E Carb Holders
- udder
23 May 2007 11:51 #142805
by udder
yeah im guessing ill need boots but this is the mount off of the engine where the boot bolts on to, the intake.
- mrbreeze
23 May 2007 12:04 #142811
by mrbreeze
Are you saying it's the head?
I think we need more pics... that looks like the boot flange that screws to the head
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
23 May 2007 12:16 #142814
by riverroad
Replied by riverroad on topic can this be fixed reasonably or i am sol
Udder, I don't know, but if it were me, I'd be looking for someone with a TIG welder that's good with aluminum. And use the old boot as a locator when he tacks the piece back on. Short of that, you're looking at buying another head I'd think.
- 77KZ650
23 May 2007 12:27 #142819
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic can this be fixed reasonably or i am sol
I think that could be welded and it would be fine. you might want to make sure its flat with a file before you put on new boots and attempt to fire it up. maybe some sort of "glue" would help solve the problem if its welded and not perfectly flat. "seal all" would be my choice as its supposed to be fine with gas and oil. i patched a metal dirtbike gas tank with the stuff once. IIRC silicone will fail after awhile if exposed to gas.
- BSKZ650
- Thank you received: 14
23 May 2007 12:48 #142824
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic can this be fixed reasonably or i am sol
I had one break like that years ago, I j b welded it, with a new carb boot on, still there, but I know it can give up at any time, make sure both surfaces are super clean and make sure you put pleanty of it on the outside too
- udder
23 May 2007 14:19 #142855
by udder
yeah its the boot mount on the head. was wondering where the air leak was ta daaaaaaaaaa lol :sick: pretty crummy. i think ill try the jb weld for now. how much is a used head? anyone have one? what would be best to make sure the boots dont leak when remounting??? also could i use it on the cracks where it broke and over the jb weld just to make sure its sealed? was gona get boots but i think i need to correct this first. ughhhhh 1 step foreward 2 steps back :S :S who carries seal all and what type of jb weld did you use?
Post edited by: udder, at: 2007/05/23 17:29
- wireman
- Visitor
23 May 2007 16:22 #142889
by wireman
Replied by wireman on topic can this be fixed reasonably or i am sol
eeeeeeeeeeeek!!!!!!!:ohmy: i thought it was just the boot!:sick: if you try and epoxy it clean it really good first with acetone .get your new boot and put a bead of clear silicone on mating surface and bolt it to head to use it as a guide for remounting broken piece jb weld or whatever you find the broken piece back on and tighten bottem bolt best you can and let it sit 24hrs the build up the outside some more try to make it look as decent as possible let it dry some more before installing carbs.save your money so you can have another head done up later;)
