Putting a 79 head on a 83 engine...
- steell
Re: Putting a 79 head on a 83 engine...
19 May 2007 16:53
Yep, I agree, it ought to work fine as long as there is enough room for the cam chain.
And it looks like there is, but sometimes it's hard to tell from pics.
- reborn650
19 May 2007 18:08
Hey Bud1 - This should head swap be interesting to hear how it turns out. I don't believe we have seen this combo tried here that I can recall seeing.
Keep us posted on your progress.
-1998 Jeep TJ Wrangler 4.0...
- Bud1
19 May 2007 19:26
Most definitely will keep you all posted.
I have this bad habit of trying to do things after I've been told it can't be done! Sometimes it works :woohoo: Sometimes it doesn't :blink: At any rate I have fun!
- SLEEPER650
20 May 2007 07:52
YOUR HEAD SWAP SHOULD WORK! AS STATED THE 79 USES A IDLER GEAR BETWEEN THE CAM GEARS. ON THE UNDER SIDE OF THE 83 VALVE COVER THER IS ANOTHER CHAIN SLIDE REMOVE IT AND INSTALL IT IN THE 79 VALVE COVER. YOU SHOULD BE GOOD TO GO!
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- wireman
20 May 2007 11:30
what part of omaha are you in ?im just on other side of 30th and harrison if you want some help;)
- Bud1
22 May 2007 23:40
Been busy the last couple days, teenage daughter problems :huh: Wireman I live on 37th Street just south of L Street. If mapquest is right we are just a few blocks apart!
- The Gringo
- ¡Usted no necesita otra motocicleta!
24 May 2007 05:37
Bud1 I was looking at another thread here and thought this would be of interest to you. It looks like you will have no problem with your head swap as long as you use the bits off the 83 for the cam chain set up. Apparently Kawasaki used the same type head with a hyvo type camchain on some of the bikes it sold in Europe. Check out the pics in this link.
kzrider.com/component/option,com_joomlab...11/id,135971/#142956
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Bud1
24 May 2007 22:36
Well, once again I've proven that when things are going to well something is about to hit the fan!
I got the 79 head all prepped, all the 83 stuff swapped over that needed to be, got the head all installed and everything, and then started to install the cams, etc.
I discovered that there is not enough room for the 83 cam chain in the 79 head. The 83 valve cover bolts to the head perfectly EXCEPT for the two bolts that are next to the timing chain. The 79 bolt holes are about 1/8 of an inch closer together than the 83. Even if I had a 79 valve cover I'd still have to grind away some of the head to get the cam and chain to seat properly.
So I've removed the 79 head and am proceeding to swap the valves from it into the 83 head.
I'll keep everybody posted on how it goes.
Gringo thanks for the link I appreciate it!
Wireman if I get stuck I just might be giving you a call!
- Bud1
31 May 2007 00:24
Well I got the valves from the 79 head installed in the 83 head without any problems. Then I started to play with valve clearances. Even with the smallest shims available there is zero clearance on all the valves. So back to the drawing board.:sick:
