Drained the oil and this came out!
- bLodi
Re: Drained the oil and this came out!
21 May 2007 14:26
Ok, I guess I am going to do this job myself. Is there anything else I need to order other than the valve cover gasket, head gasket and new chain guide? Any special tools I should be aware of? I have the CD rom manual, but it can be pretty unclear sometimes.
Thanks.
Thanks.
www.blodisign.com
\\\\\\\'74 Z1
V&H 4-1 Header, Pod Filters, Dyna Ignition, Dyna Coils, Dyna Wires, lowering kit...much more.
\\\\\\\'74 Z1
- Rob
21 May 2007 14:52
this is what it will probably look like when you pull the head and look down there. it kinda sucks all the work for a 15.00 part.
Located in Cleveland, Ohio
78 kz1000LTD (project)
- bLodi
21 May 2007 15:30
Rob wrote:
How long did it take you to do?
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
- Rob
21 May 2007 16:01
oh if i recall right i think it took me about one saturday to tear down and repair but im not as fast as some of the guys around here:laugh:
one thing is you will get to know your motor real well:laugh:
Rob
Rob
- bLodi
21 May 2007 16:08
Rob wrote:
Did you need any special tools like a cam chain breaker or anything?
Rob
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
- Rob
21 May 2007 16:36
no special tools required...you dont have to remove the cam chain just dont let it fall down into the bottom cases.i tied mine to the top of the frame until i got the cylinders off of the pistons and then put a screw driver through the chain so it couldn't fall.... oh you will also need a base gasket.
Rob
Rob
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
21 May 2007 16:48
I had to use an impact driver with an extra long bit to remove the screw holding the guide in. It was in there real tight.
While you're in there, also take a look at the cam chain tensioner assembly. Mine had the metal worn through, and it was coming apart. You can also get these from Z1 Enterprises.
West Linn, OR
- Sandy
- Fly High,Tony
21 May 2007 19:44
You'll need a head gasket as well.Also...while You have the head off,You should pull the valves out and lap them,and replace the guide seals as well.The seals are cheap,and You'd be a Fool not to replace them now,while You have it all apart.Chances are,they're old and dried out.Lapping the valves and having a good look through the head is a good idea...peace of mind.
1977 KZ1000 A-1
- donthekawguy
22 May 2007 01:45
Maybe even throw a set of rings in it while you have it apart.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- mark1122
- Keep twisting it
22 May 2007 02:21
You may as well order a complete gasket kit from Jeff at z1e.Its cheeper than seperate 1's, and you will have all the side cover gaskets and valve seals and exhaust o rings and and and and.....
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
