Honda pistons for KZ1000
- KawasakiJockey
13 Apr 2007 19:05
Do any of you guys remember the Honda 500 pistons that fit the KZ? I think you had to hone the stock bore out some and they worked great but gave higher compression. I cant remember for the life of me..
- Sandy
- Fly High,Tony
Re: Honda pistons for KZ1000
14 Apr 2007 10:27
Hmmm...don't know about the piston thing,but I do know that some of the Honda CB starters will fit the KZ's.
First I've heard of pistons though:huh:
1977 KZ1000 A-1
- 77KZ650
14 Apr 2007 23:00
ping APE Jay?
07 MDP Rookie of the Year
- craigpuckett
15 Apr 2007 18:35
I think I remember a bench racing story where the early kz guys used CB450 DOHC pistons,they had to remachine the valve reliefs as the cb had different valve angles.
could be true,could be fiction, mabe someone else will confirm.
- APE Jay
15 Apr 2007 21:12
I used CB450 3rd over pistons to make 1038 kits for Kaws. Can't even begin to imagine how many hundreds of those kits I made.
Jay
Jay
- KawasakiJockey
16 Apr 2007 20:14
OOkaay..cool. A guy I know has a 1000 engine with the Honda pistons in it. This was done years ago and its time for rings.
- inline4
16 Apr 2007 20:21
As usual,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Jay is the man!
Jay is the man!
- Mr. E
10 Jul 2021 07:10 - 10 Jul 2021 07:11
APE Jay post=130589I used CB450 3rd over pistons to make 1038 kits for Kaws. Can't even begin to imagine how many hundreds of those kits I made.
Jay
Hey I'm curious, did the pistons need cut for valve pockets?
1977 kz1000 - the Rooster, 1981 KZ750 Chopper, 1975 KZ400 , 1984 GPZ750
Last edit: 10 Jul 2021 07:11 by Mr. E.
- Mr. E
10 Jul 2021 07:12
Any modifications to the pistons needed?
- zed1015
10 Jul 2021 07:23I had a Z1 bored out to 1015cc (70mm).Any modifications to the pistons needed?
That was pre Z1000 and before aftermarket piston kits were available.
It used two sets of Honda CB500T pistons.
They were higher comp than stock when used in the 900 motor but they dropped straight in with no mods needed to the valve pockets or anything..
- z1kzonly
10 Jul 2021 12:42
Plus, XS 1100 Yamaha pistons. I used these a couple of times. Came out to 1060cc on the Kaw 1015 block.
The following user(s) said Thank You: Mr. E
- Mr. E
15 Jul 2021 17:21
Hmm so the xs1100 big bore kits should fit hmmm
