Tach Drive Oil Leak
  • JR
  • JR's Avatar
Re: Tach Drive Oil Leak
28 Mar 2007 16:09
#124424
faucet washer from and assortment pack worked for me. Must be 4 years now and like KazooCruiser says "no drool".
  • dkmk
  • dkmk's Avatar
28 Mar 2007 17:44
#124439
I had a b**ch of a time trying to get mine out the other day. Slightly scored the guide axially back of the o-ring toward the cable end, and a little on the bore. Had to clean it up with a little fine emery cloth and a small flap wheel in valve housing. The fit is tight, but not what it was.
Anyone ever cut a second seat for an additional o-ring, similar to a piston with the double cup seals in a brake m/c? Maybe 1/8" in from the chamfer, and it could catch anything the first missed? I know an excellent machinist who loves a challenge. Just a thought. I don't want to have to do it twice. B)
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
28 Mar 2007 19:26
#124464
dkmk wrote:
... b**ch of a time trying to get mine out the other day. Slightly scored the guide axially back of the o-ring toward the cable end, and a little on the bore. Had to clean it up with a little fine emery cloth and a small flap wheel in valve housing. The fit is tight, but not what it was.
Interesting question and unsurprising for a part remaining in place for maybe 30 years. In worst case scenerio, a new housing is available from Z1E for $30.
But I would consider first cleaning the opening with acetone, then a new shaft seal (inexpensive from Z1E)) with a new o-ring on the old unit and supplementing the o-ring seal with an application of Permatex hi-temp copper (comes in a squeeze tube from any auto-supply store). Believe this would assure a complete long lasting seal.
Believe your idea about the second o-ring would also work if there's enough metal thickness in the unit. Interesting question, because very dim memory recalls some of these units were originally fitted from the factorey with 2 o-rings. (Could be a just a mirage :unsure:)
  • Bluemeanie
  • Bluemeanie's Avatar
29 Mar 2007 05:28
#124538
When I tighten down mine it bottoms out and cable is still loose. Had to add an extra gasket to snug it. BTW, I had the same nasty leak but the kit from Z1 fixed it!
  • kzwolfsr
  • kzwolfsr's Avatar
29 Mar 2007 19:15
#124760
I never had a seal or an O ring for mine, I just got some liguid sealant, pulled that movable screw on part up the line, then put the sealant around the flange part of line and let it dry a little thenbrought the screw on part back down and squished it onto the sealant while screwing it on and my bike seals pretty good, and I must add, I put all 4 quarts into my bike without looking back. I gave you my dollar LTD, and I try my best to keep my bike sparkling like yours..... See post pics from the past weeks
Original man of the Caribbean
  • boomboom45
  • boomboom45's Avatar
01 Apr 2007 15:42
#125624
anyone have the kit link, from z1 enterprises, or tell me barney style how to fix this?
  • z1rick
  • z1rick's Avatar
01 Apr 2007 15:56
#125629
www.z1enterprises.com/catalog.aspx?pid=KZ900-A4-1976-EN0
Go to page 5 I think it is...
Post edited by: z1rick, at: 2007/04/01 18:58
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
