Head Swap
- Duck
- e vica na i sau na ga
Re: Head Swap
09 Mar 2007 11:51
1200 Sleeves...
Are there any that can be salvaged from other model bikes or cars to avoid spending the $300 or so that the APE or LA parts costs?
FWIW, the ticker repair is holding so far. Did a brisk 15 min, nonstop, walk this AM. Hopefully will be cleared to ride at 21 or 26 Mar doc visit.
50 percocets down, 50 to go
-Duck
-Duck
- wireman
Re: Head Swap
09 Mar 2007 12:36
cool ,listen to what they tell ya.the Ape street kit comes with sleeves.its the higher compression and turbo kits you need to buy sleeves for.unless youre a cheap bass turd like me and have a collection of 1197 pistons laying around and not enough sleeves for all of them!
- larrycavan
Re: Head Swap
10 Mar 2007 04:32
77KZ650 wrote:
There isn't enough difference in flow to justify the swap based on larger port runners alone.
If you're runnin 29's on the motor, stay stock KZ head. Even up to say 34mm carbs, I'd stay stock KZ head for a moderate size street motor.
Lot's of people get the wrong impression that installing a J head on a KZ motor relates to big power gaines...don't fool yourself...it takes more work and more components to make that assumption a reality...
Larry C
wiredgeorge wrote:the j head has bigger ports to go with the bigger valves, so just putting j valves in the old head without porting wouldnt be as good as running the j head with the right compression.The J motor valves are a tad bigger. Not sure if the loss in compression and resulting horsepower would make sense. Perhaps you could put a couple gaskets on to get compression back upadding gaskets lowers compression as its just like doing the opposite of milling the head or cylinders but this would be a headache. If you want to go with bigger valves, buy the valves, get a valve job done on your old head as a decent performance shop could install the larger valves in the old head and you won't have to worry about adapting the cam chain idler arm and figuring out how to bump compression back up. Stock compression is 8.25:1 and that is about where you would end up.
Larry C
- larrycavan
Re: Head Swap
10 Mar 2007 04:44
Actually Wireman...that was my "rant" on another forum after I read what I considered to be a lot of misinformation....I'll stand by my post...I also did apologize to the guy for hammering on hims so hard..
There is a point where the J head makes good sense and a point where it can't be justified to swap...
- Bad Kaw
- Flying Squirell
Re: Head Swap
10 Mar 2007 05:51
Lots of good 'scoop' here. 'Well said' to all of you. I believe that the J/GPz heads offer moderate improvement stock::stock, and great potential improvement when going with big modifications. And I believe all of you agree on this...now, who has that '84 GPz 1100 head that you're wanting to sell me on the cheap for my '78 Z1R big block? :woohoo:
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- wireman
Re: Head Swap
10 Mar 2007 09:00
larrycavan wrote:
)we think so much alike!
thats why i love this guy(:blink:Actually Wireman...that was my "rant" on another forum after I read what I considered to be a lot of misinformation....I'll stand by my post...I also did apologize to the guy for hammering on hims so hard..
- larrycavan
Re: Head Swap
10 Mar 2007 15:59
wireman wrote:
Sure seems that way to me.....I like no nonsense people...
larrycavan wrote:thats why i love this guy(:blink:Actually Wireman...that was my "rant" on another forum after I read what I considered to be a lot of misinformation....I'll stand by my post...I also did apologize to the guy for hammering on hims so hard..
There is a point where the J head makes good sense and a point where it can't be justified to swap...)we think so much alike!
- APE Jay
Re: Head Swap
10 Mar 2007 19:20
Whoever wrote the big long post have a number of errors. The most blatant is that a J head can take a 42mm intake valve without changing the seats. NOT SO. 38.6mm. max
Jay ( One who has put a lot of big valves in a lot of J heads.)
Post edited by: APE Jay, at: 2007/03/10 22:21
- larrycavan
Re: Head Swap
11 Mar 2007 13:56
APE Jay wrote:
True.....
Post edited by: larrycavan, at: 2007/03/11 16:58
Jay ( One who has put a lot of big valves in a lot of J heads.)<br><br>Post edited by: APE Jay, at: 2007/03/10 22:21
True.....
- Jack
Re: Head Swap
12 Mar 2007 13:05
Interesting reading, thanks. With the head porting, agree that velocity not cfm flow is more important.
Sent the 84 GPZ head from my race bike to a well known cylinder head shop for a valve job and a "second opinion" It's got 42mm.in and 34mm. ex & was told I'd have to put bigger valves in it to maintain velocity.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- larrycavan
Re: Head Swap
13 Mar 2007 18:42
Jack wrote:
That would be true only if CFM increased on a scale proportional to cross sectional area.
Velocity if a component of volume and cross section. If volume [CFM] is increased while maintaining the same cross sectional area, then velocity goes up. If CFM increases because of an increase in CSA then velocity can remain the same or even drop. Just depends on the balance of volume and area as to which happens.
In any event, it's not going to mean diddly to most people. All they want to know is the bike went quicker/faster...
- wireman
Re: Head Swap
13 Mar 2007 18:47
larrycavan wrote:
:ohmy: wow,that went right over my head!Jack wrote:Interesting reading, thanks. With the head porting, agree that velocity not cfm flow is more important.
