- Thank you received: 2
Engine removal
- henrymski
I am about to remove the engine from my 1000 and I am doing it by myself. I've read that if I lay it on it's side, I can pull the frame off of it. My questions are:
Which side do I lay it over on?
Should I remove the head or anything to lighten it up?
TIA.
H
- wiredgeorge
- rstnick
- Thank you received: 377
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- DanOz7Five0
Hope that helps or at least isnt too far off topic.
- 900cows
- henrymski
I have a two ton floor jack, I have a square metal plate welded to an extra support head with two three quarter inch rods welded to the plate. with every thing striped and ready to go, i install studs in the exhust side,(top,all straight across). Then i install some intake studs. Be sure to bottom the studs, more support!!! Roll the jack up to the bike from the side, the welded rods can rest and lift the engine from under the studs. jack intill the needed hieght. pull engine assembly slowly out. time and time again...The trans weight will want to pull the engine down on intake side tho. faburcate square tubing under three quarter inch rod to compensate. basic,leverage.
If only I had a floor jack...or a welder...
- dgfischer
- Visitor
Daniel
- Garn
- Thank you received: 13
Post edited by: Garn, at: 2005/12/07 17:18
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- lotsofink
Ink
- Garn
Sydney Australia
- kawtoy
- Thank you received: 6
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- Garn
You then have the engine hanging on the pipes and the frame to the LHS, with the water pipes not allowing it to be separated. You then support the engine by blocks or jack and move/drag the frame away by temporarily removing the LHS supporting saw-horse. Regardz.
Sydney Australia
