998 Cylinder Boring
14 Dec 2005 04:43 #13081 by Russ
Replied by Russ on topic 998 Cylinder Boring
If you wanted to go for the 1105 kit I believe an GPZ1100 block drops straight in to the Z1000J crankcases and then it's only a 0.5mm overbore or you could go to an 1170 kit
14 Dec 2005 04:48 #13083 by craigpuckett
Replied by craigpuckett on topic 998 Cylinder Boring
I would have to measure,but I have been told that the 1000j cases would need to be bored to take a gpz1100 block.
anyone with firsthand info?? or do I need to get out the calipers??
  • Duck
  • e vica na i sau na ga
14 Dec 2005 04:51 #13084 by Duck
Replied by Duck on topic 998 Cylinder Boring
Thanks.
I think my KZ1000A1 might have been modified. It's got no through holes in the block. I'm still working on it, slowly because it's my baby and I want to do everything on the GPz1100 or the KZ1000P for 'practice' before tackling on the A1. If I bugger something up it's not gonna make me feel as bad if I do it on a ratty old $150 police bike ;-)
I'll be checking valve clearances once I get all the chassis work done and can have a look at the timing chain galley then. If it was modified, it was done way back in late 70's or early 80's. Who was making hotrod parts then?
-Duck
14 Dec 2005 19:10 #13241 by wireguy
Replied by wireguy on topic 998 Cylinder Boring
everybody was making parts to hotrod zbikes back then it was big business between them and suzuki!R.c engineering,yoshimura,wiseco,mtc,web-cam,cam-motion,sid pogue was selling his own big-blocks,kerker,supertrap,the list goes own forever!if you have a really old bigblock with no name it could of been from pogue engineering in oklahoma city,is he still around how about bob carpenter? does anyone remember jessie gatlin racing("the gatlin gun")?maybe im just getting too old!
  • APE Jay
  • Visitor
15 Dec 2005 17:27 #13379 by APE Jay
Replied by APE Jay on topic 998 Cylinder Boring
Does it have fins across the end of the block, or is there a square where a logo could go?
Jay
28 May 2006 12:17 #50628 by Maverick
Replied by Maverick on topic 998 Cylinder Boring
Anybody have experience putting the GPZ1100 cylinders on an unmodified KZ1000J engine case?
1981 KZ1000M1
  • APE Jay
  • Visitor
28 May 2006 15:35 #50649 by APE Jay
If you don 't mind splitting the cases so you can bore the top case out, a GPZ block allows you to do an 1170cc with only cylinder boring.
Jay
29 May 2006 08:22 #50736 by no name
Replied by no name on topic 998 Cylinder Boring
a GPZ1100 block fits on a 1000J case without any problems.
29 May 2006 13:41 #50769 by craigpuckett
fits,but just try bolting it down without clearing the cases,can you say cracked cases.
if you have,I would check the cases when you take the block off to see if there isn't a stress crack around the web
30 May 2006 08:40 #50903 by no name
there is enough place for the 1100ccm sleeves.
Cylinder fits without any problems and the upper case was not grinded.
01 Jun 2006 19:36 #51488 by rpkaw
Replied by rpkaw on topic 998 Cylinder Boring
The 1100 block will fit the 1000J cases without any problems. I have a 1000J with the 1100 block bored to run 1135 wiseco's and it has been run this way since 1990.I'm now in the process of freshening up the engine and am reusing the same pistons on an 1100 block. Rering and lightly touch up the valves. I personally would not run the 1170's in the 1100 block. Sleeves are getting thin at that displacement plus it will likely overheat.The 1135's in my J run quite a bit hotter than stock.An 1105 kit in an 1100 block should be pretty good for a street bike.Might try that on my gpz 1100.
