piston weight /engine balance
- wallyworld
- wireman
- Visitor
- APE Jay
- Banned
- Thank you received: 58
Wiseco pistons are very close to each other in weight.
Jay
- jimmybon
- Thank you received: 2
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
- wallyworld
- wireman
- Visitor
- 77KZ650
- Thank you received: 7
you probably wont notice much if anything if you take some material off of the pistons unless you are a competitive racer, and making the piston shorter by taking material off of the bottom makes the piston more likey to "rock" in the bore and make it wear out faster and make the cylinder out of round. its a common problem on big bore single cylinder motors when the bore gets too big. they have to keep the piston "short" to keep it from hitting anything. From what I hear, drilling holes in the skirt is the best way to lighten them up as it doesnt shorten them anythe pistons are heavier because there bigger, all that extra horse you get will far out way the extra piston weight. I thing they grind, machine or file the bottom of the skurt to balance
07 MDP Rookie of the Year
- modprod
thanks guys,I'll just get them all done to the lightest piston on my paint scale. I just tig welded the 900 crank [didn't add or lose any material, just stirred it around alittle] everything should be in pretty good balance at the bottom. the next thing willbe the valve springs[I've heard it is quite important to have them all close to the same spring rate and pressure] any ideas?
If you want to perfectly balance your pistons, you would need a triple beam scale to weigh them. Straightness/balance of the crank and balance of the clutch basket would probably make a more noticable difference but for a street bike these pistons weight differences won't be enough to warrant the effort required
- wallyworld
- 77KZ650
if you have 2 chunks of material that weigh the same, that are connected to a shaft that is spinning, but one chunk has more material out farther that the other, it wont be balanced even though the parts weight the same. if that's not clear, I'm not too great at describing stuff... say the 2 chunks started out the exact same shape, but you drilled a hole in each one, but not in the same place, they still weigh the same because you removed the same amount of material, just from different spots. the one with the hole closer to the shaft has more mass/material further out than the other one that has its hole farther from the shaft.
its kinda like balancing a tire on a rim, only they don't add weights, they remove material in the proper location
I know a guy that has a set of scales like that, but he doesn't weight paint:P :whistle: :laugh:
- steell
- APE Jay
- Banned
