New Rings Installed--When to check compression?
- PLUMMEN
Re: New Rings Installed--When to check compression?
11 Jul 2007 16:43
have you checked/adjusted your valves since rebuid?
- Duck
- e vica na i sau na ga
11 Jul 2007 17:36
Keep riding. If it's fun and running well, I would not worry about it.
PS. If your comprssion tester uses a Schrader valve, make sure it's not leaking. They get fouled easily.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
11 Jul 2007 21:12
PLUMMEN wrote:
Oh, yes. And a leakdown test confirmed that the leak is at the pistons.
West Linn, OR
- Skyman
11 Jul 2007 21:16
Duck wrote:
I will keep riding until winter. Then I think I'll take a peek inside. I just can't let a known problem go unchecked forever.
As for the guage, I did borrow another gauge to double check the readings. No difference.
Post edited by: Skyman, at: 2007/07/12 00:17
West Linn, OR
- Kiwiz
11 Jul 2007 22:50
your method of breakin sounds good to me. If it runs well, has plenty of power, doesn't smoke who cares what the gauges say???
I just rebuilt my J and adopted the break in yu used. She' fine and I havent even bothered to check the PSI. Dont worry ride happy!
