running straight headers??
- wireman
Re: running straight headers??
14 Feb 2007 04:24
GPzephyr wrote:
cold air does bad things to hot exhuast valves,used to do that when i was young and dumb before i knew back pressure was a good thing on street motor!:whistle:Excuse me for sounding stupid.But why would low back-pressure burn your valves?
I was always brought up on lower is better.
- steell
14 Feb 2007 05:14
GPzephyr wrote:
If the pipes are long enough, then it won't.
It normally happens when running either no pipes or very short ones, what happens is the valves get really hot and when you shut it off cold air gets to the valves and causes them to warp. When the valve warps it no longer seals against the seat and exhaust escapes during combustion. I have seen notches cut into a valve due to the plasma cutting effect of escaping combustion gases.
- tnutz
14 Feb 2007 17:03
So it's not to bad with a long piece of straight pipe in there? i am already jetted for a header and Free flow muffler. i still want one for beach days, but wanna keep it quiet in the city. I really want it on the 1100, but with the efi i have no way to compensate for it.
Post edited by: tnutz, at: 2007/02/14 20:08
- 77KZ650
14 Feb 2007 22:38
tnutz wrote:
any way to hook up a power commander or yosh box? or better yet just go mega(or micro) squirtSo it's not to bad with a long piece of straight pipe in there? i am already jetted for a header and Free flow muffler. i still want one for beach days, but wanna keep it quiet in the city. I really want it on the 1100, but with the efi i have no way to compensate for it.<br><br>Post edited by: tnutz, at: 2007/02/14 20:08
07 MDP Rookie of the Year
- steell
14 Feb 2007 22:43
Have to switch to later model throttle bodies or adapt a TPS to the original ones, hard to believe but the early model throttle bodies basically had an on/off switch instead of a TPS. I didn't believe it myself when it was first posted here so I checked a set I have, and it's true.
- themachine
14 Feb 2007 23:00
i always though it was the super hot exhaust gases being blown through the valves too fast due to it being too free flowing, kinda like a plasma cutter, or a cutting torch.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- steell
15 Feb 2007 07:15
themachine wrote:
Nope, that's the purpose of porting isn't it, to get the exhaust gases out faster?
The exhaust valve and port size/shape limit the speed of the exhaust gases, just like on the intake side.
It takes time to transfer heat, the less time the valve is exposed to exhaust flow the cooler it runs.
- GPzephyr
16 Feb 2007 14:25
steell wrote:
Yup! that makes sense. Especially regarding no or very short pipes.
So the length of a typical street system isn't likely to suffer from this, regardless of how low the backpressure is. The cold air simply isn't going to be able travel up the pipes to the valve. Disregarding the noise factor of course.:blink:
GPzephyr wrote:Excuse me for sounding stupid.But why would low back-pressure burn your valves?
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- Chris78LTD
17 Feb 2007 13:47
Why would you even want to think about not running pipes?
- larrycavan
17 Feb 2007 16:36
tnutz wrote:
Oh yes you can!...compensate with EFI that is..
The 81 had the older analog setup but you can still tune it to a degree, certainly enough to compensate for a pipe.
Adjustable Fuel Pressure Regulator will get the job done.
- tnutz
- tnutz
