  • Page:
  • 1
  • 2
wiseco 810cc kit? 04 Feb 2007 21:13 #110280
  • reborn650
  • reborn650's Avatar
  • Thank you received: 5
cottoncandyninja wrote:
one other thing i forgot to ask. does anyone have a rough idea what kind of power increase putting that kit on my bike will do to the stock 74 claimed ponies it makes? five hundred hard earned ones is alot for just a ten horse increase, unless my torque goes through the roof? just another question i have to help make me salivate better about what this COULD turn into. the little 3/4 liter bike that could. :woohoo:
Hey CCN - I put the 810 Wiseco kit into my '77Kz650 last season so I have a little experience with this package.
It is definitely more powerful than the stock 650 and the Wiseco 700 kit I had in the previous season. I run premium gas and haven't had a problem with the 10.25 to 1 compression ratio for the 810 pistons I put in the 1980 Kz750 cylinders which were bored out to handle the 810 pistons.
I ported, polished and milled the 650 head 10 thou to clean up the mating surface, put in Gpz 750 intake valves that were trimmed 15 thou, left in the stock 650 exhaust valves and swapped in the hotter Kz750 cams. I recently switched to Mikuni 29 smoothbores that I purchased from Wired George to replace the 28's I had on the bike for the 2006 riding season. The 28's seemed to come up a bit short in hard acceleration runs. I have a MAC pipe, velocity stacks and Dyna ignition/coils.
Power guesses are just that...guesses unless you put the bike on a dyno. With the unscientific seat of the pants assessment, the 810 is a far stronger performer all the way through the powerband. I also changed the front sprocket from the stock 16 tooth down to a 14 tooth and this really helped acceleration off the line. I don't drive on the highway so this combo is nice for 0-75 mph my style.
I think it is reasonable to expect that my combo will run at least as quick as a stock Kz1000 given the 650/810 is a slightly lighter package. I also base this on the view of a fellow Kz1000 owner who said that my 810 pulled a lot harder than his well-tuned 1000 did. I also had some runs up against a slightly modified '82 Kz750 that I easily outran at various speeds.
The bottom line is that if you build it correctly you won't be disappointed and will likely suprise some larger bikes with the 810 punch. Do a search in the archives on the 810 and you will find a lot of good ideas on how to upgrade your 750's performance.
1977 Kz 650 Custom - Miss January on the 2007 Kzrider.com calendar.
Post edited by: reborn650, at: 2007/02/05 01:00
-1998 Jeep TJ Wrangler 4.0...
wiseco 810cc kit? 11 Feb 2007 16:18 #111632
  • dudley4
  • dudley4's Avatar
  • Thank you received: 0
I have kz750 L3 with 810 kit milled head, stock cam for now (still looking gpz cams) night and day difference. also have ran 29 smoothbore and the bs34. both are nice after I got the jetting just nuts. bs34 win for the street carb, they fill stock just putting around on the street or they will run like a stripped a$$ ape when opened up.:ohmy:
wiseco 810cc kit? 11 Feb 2007 17:30 #111661
  • gpzrox
  • gpzrox's Avatar
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
wiseco 810cc kit? 11 Feb 2007 18:05 #111672
  • steell
  • steell's Avatar
  • Thank you received: 207
You don't want Turbo cams, they have exactly the same specs as standard KZ650 cams.
The head for the E1 (Turbo) has a different part number than the head for the A2 (non Turbo), but I suspect the reason is probably the temp sensor.
wiseco 810cc kit? 08 Jun 2019 11:32 #805361
  • Cailly
  • Cailly's Avatar
  • Thank you received: 3
Just did the final Dyno run today on my GPz750 racer, Wiseco 810cc kit, pod filters and free flowing exhaust ... drumroll ... 77,89HP at the rear wheel, so about 90+BHP. Hope this helps settle the matter. Pic of the printout attached
wiseco 810cc kit? 08 Jun 2019 12:03 #805363
  • Thank you received: 2829
You are replying to a posting that is more than 12 years old. :laugh: Ed
wiseco 810cc kit? 08 Jun 2019 12:05 #805364
  • Cailly
  • Cailly's Avatar
hahaha, I have come across this post the most while searching for that HP figure !
wiseco 810cc kit? 11 Jun 2019 13:23 #805524
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Cool bike! :)
What type of speedo/tacho do you have?
Project:
wiseco 810cc kit? 11 Jun 2019 13:51 #805526
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
gordone it Looks like an Acewell ACE-2753 / ACE-2755 / ACE-2766
wiseco 810cc kit? 16 Jun 2019 09:10 #805829
  • Cailly
  • Cailly's Avatar
acewell - all digital, works well but there are better ones for sure
wiseco 810cc kit? 16 Jun 2019 09:52 #805837
  • gordone
  • gordone's Avatar
Which is better?
I don`t want proximity switch etc...
Project:
wiseco 810cc kit? 17 Jun 2019 09:46 #805929
  • Cailly
  • Cailly's Avatar
motogadget - cream of the crop, I have the m unit fusebox its a treat to work with makes everything so neat and simple
  • Page:
  • 1
  • 2
