engine oil for 78 KZ650 D1
- FlyingSlow
Re: engine oil for 78 KZ650 D1
18 Jan 2007 13:57
OKC_Kent wrote:
Good info, thanks. I'm going thicker next time anyway to see if I can stop some of this seepage without having to replace gaskets.
Do not use auto oil with the "Energy Star" on the bottle, that stuff MAY make your clutch slip. Once you get into the 10w-40 and thicker oils you don't see that Energy Star too much.
- KaZooCruiser
18 Jan 2007 15:01
I use 15-40 automotive SJ all the time in everything I maintain. Goo out at 3,000 miles, a gallon in, with the filter. I add, using the sight gauge, as needed between changes, and at 43,000 miles, I don't see a need to change the routine. As far as the transmission is concered, a lot of car manufacturers used motor oil to lube the tranny, so Kawasaki Heavy Industries kind of followed suit. ATF would be a good choice to deal with clutch issues, but then you get into whether type F or Dexron in appropriate, plus then you might end up with a broken engine due to it's being used in a shared engine / tranny setup.
Post edited by: KaZooCruiser, at: 2007/01/18 18:12
