Engine can't start! Please help me....
Re: Engine can't start! Please help me....
22 Jan 2007 13:20
All here glad to help and anxious to see you up and running.
Try removing air filter and spray starter fluid into air intake while cranking in usual manner with choke OFF and throttle closed and petcock OFF. Be sure kill switch is in run position. Hope it runs a few seconds then dies.
Next -- same procedure except turn petcock ON. Hope it cranks and might keep running without choke.
If cranks and runs but dies with no choke -- pull the choke lever UP -- leave throttle closed -- leave air filter out --attempt to crank with NO starter spray.
What are the results?
22 Jan 2007 13:37
When cranked and running, should change oil and filter before road testing (remember earlier advice from WiredGeorge).
And maybe you need some help with removing the damaged oil drain screw.
- austin3119
27 Feb 2007 22:41
Sorry to bring up an old thread guys, but did you get your bike up and running?
- OKC_Kent
28 Feb 2007 12:55
I got to thinking his plugs were so wet they just went bad, it can happen. It sounds like lots of fuel in his oil. I would buy brand new plugs, change the oil, charge the battery, check for spark, and see what happens.
Cashion, OK
78 KZ650 B2 85,000+ miles
- wireman
28 Feb 2007 13:18
is the kill switch on?not that ive ever done anything like that!:blush: :whistle:
