MKII crank
- 79MKII
- Love Them Kaws!
Re: MKII crank
09 Jan 2007 17:37
APE Jay wrote:
Well, I liked this idea so much, I bought a 17mm rod from McMaster-Carr for $15.65. The problem is I can't even get it through ONE rod!!:blink: My wrist pins and the rod measure 16.98mm, so what on earth am I doing wrong? Do I need a wrist pin installation tool or something?? I though it would be a quick and easy check.
Post edited by: 79MKII, at: 2007/01/09 20:37
Many of the leading tool supply companies have precision ground steel rod in three foot lengths in metric sizes. Most call it drill rod.
You can get a 17 mm diameter piece for about $23.00.
This is what you use to check it the crank is in index. If it will fit thru all four rods, the crank is OK. If the crank is twisted out of index, the rod will ususllu go thru three rods, but not the last one.
Jay<br><br>Post edited by: APE Jay, at: 2006/12/25 01:02
The Kaw List:
- steell
Re: MKII crank
09 Jan 2007 18:09
Bevel the end of the drill rod, it will make it a lot easier.
- donthekawguy
Re: MKII crank
09 Jan 2007 21:28
It's worth the $200 or so to have it welded and get the plate. If you really want to go crazy you can have the tranny gears cut. That way when you get bored with it you can bore it out and get bigger cams and not have to worry about the bottom end.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- 79MKII
- Love Them Kaws!
Re: MKII crank
10 Jan 2007 14:08
steell wrote:
That was the first thing I tried last night...no luck:angry:
Should the piston pins push through the rods by hand?
The Kaw List:
- larrycavan
Re: MKII crank
13 Jan 2007 06:23
79MKII wrote:
Absolutely! Without force of any kind.
steell wrote:Bevel the end of the drill rod, it will make it a lot easier.
- Jeff.Saunders
Re: MKII crank
13 Jan 2007 09:48
With the rod I purchased a few years ago, I had to use some fine wet & dry paper on the outside to reduce the diameter very slightly - you want it snug, but not tight.
www.z1enterprises.com
Z1 Ent on Facebook,
- Jeff.Saunders
Re: MKII crank
13 Jan 2007 09:48
Z1 Ent on Facebook,
