Show me your motorcycle lifts
Re: Show me your motorcycle lifts
16 Apr 2023 14:53 - 16 Apr 2023 14:54
Injected you roll with some big shooters. What a beautiful 900!
Last edit: 16 Apr 2023 14:54 by Mikaw. Reason: Spelling
The following user(s) said Thank You: Injected, SWest
- Injected
16 Apr 2023 16:14 - 16 Apr 2023 16:17Yep, its not quite stock is it.Injected you roll with some big shooters. What a beautiful 900!
He's had that bike since 1978 but he recently stripped it down and gave it a face lift (fresh paint job and shined it up)
Its just a warmed over 1015 with mild port work, Yosh Bonneville cams and RS34's, not too radical.
Chassis setup is very 1980's road racer style.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 16 Apr 2023 16:17 by Injected.
16 Apr 2023 16:42
This is the place to get lifts locally in Michigan and they ship too
aresco.org/motorcycle_lift_main.html
- Dragbike_Mike
17 Apr 2023 05:59
Add me to the list of satisfied Handy lift owners. I've had mine since 1995. Built like a tank and I'd describe it as "heirloom quality" in that it'll last you several lifetimes. Right now, it sits in my basement workshop. No complaints!
Mike
Mike
Presently - 1980 KZ1000B4 LTD w/mild ported head, Megacycle cams, 1015cc Wiseco, Falicon Supercrank, R&D undercut trans
- KZQ
- Administrator
17 Apr 2023 16:18
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
The following user(s) said Thank You: Nerdy, Wookie58, Kelly E
- Nerdy
17 Apr 2023 16:20I stretched an ATV lift.
That's a really good idea!
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Kelly E
17 Apr 2023 20:43
I bought a lightly used Harbor Freight lift table for $175. Then one day I noticed the old twin bed frame sitting in the corner of the shop. It hit me that I could turn it into 11" wide removeable side tables with two cuts and no waste. The angle iron 32" crossbars cut in half leave 11" sticking out from under the deck when butted up against the frame rails. Two bolts with wing nuts attach the four crossbars on each side for quick release. A little welding and drilling of holes I have side tables for my lift table using junk and scrap, my favorite way to build stuff.
I removed the wheels, welded nuts on and screwed in bolts for adjustable feet when lowered. It also makes a good work table when there's no bike on it.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- slayer61
- KZR FLAG RELAY CARRIER #62
23 May 2023 08:29
A buddy recently purchased the same HF lift that I have. He was so taken with the IDEA of the lift, he bought me a front wheel clamp for my 20 something year old lift. Thanks Gregory!
The following user(s) said Thank You: ThatGPzGuy, Wookie58
- Kelly E
23 May 2023 09:13
How do you like the wheel clamp? That clamp is way better than the original clamp.
I've never used the one that came with my lift table except to hold wood while I was cutting.
Most of the time when a bike goes up on my lift table it is going to be taken completely apart, even when I tell myself that I'm not going to do it this time.
1983 Honda CB 1100F
And more
1983 Honda CB 1100F
And more
- slayer61
23 May 2023 09:49I like it just fine. My buddy, the supplier of the clamp, was of the opinion that the clamp would be fine to hold the bike up & you wouldn't even need tie downs! I did find that that the clamp held the bike long enough to get the tie downs in place!How do you like the wheel clamp? That clamp is way better than the original clamp.
