Show me your motorcycle lifts
Re: Show me your motorcycle lifts
14 Jun 2020 18:51
Hey urankjj,
Hope that photo is from when you jacked up the bike to change that rear tire! Too many smokey burnouts on that one.
The following user(s) said Thank You: urankjj
- slayer61
- KZR FLAG RELAY CARRIER #62
17 Jun 2020 08:30
Another vote for the Harbor Freight.
I bought mine brand new & has served me well for the last 12 years or so...
man I can't believe this is the only picture I have :dry: :dry:
- urankjj
17 Jun 2020 17:04
Yes that is true. All the mileage on that tire definitely went up in smoke. But it sure smelled good gettin there.
- Givusaclue
18 Jun 2020 10:19 - 18 Jun 2020 10:21
i have an abba lift, my Z750L4 goes on it a treat, you just need the right size adapters that fit the swingarm
Last edit: 18 Jun 2020 10:21 by Givusaclue. Reason: Adding photo
The following user(s) said Thank You: Scirocco
- 9er rider
- Keep a cool tool
18 Jun 2020 10:55 - 18 Jun 2020 10:58
Looks like good mechanic aerobics and no place to put tools and parts. I often use my lift for extra adjustable work bench.
Last edit: 18 Jun 2020 10:58 by 9er rider.
- Dr. Gamma
18 Jun 2020 11:12
Looks like you can't pull swing arm with that fancy lift.
Can you pull a motor, or install a motor with that lift.
1986 RG500G 2 stroke terror.
- Dragbike_Mike
18 Jun 2020 11:56
Presently - 1980 KZ1000B4 LTD w/mild ported head, Megacycle cams, 1015cc Wiseco, Falicon Supercrank, R&D undercut trans
18 Jun 2020 11:56 - 18 Jun 2020 12:01
Really, who need a ABBA lift to pull a swing arm or to pull or install a motor?
Did you only use your Harbor Freight lift for the same Task??? Nada!!!
Every lift or stand has his pro and cons but only the ABBA lift is able to move a lifted bike!!!
Last edit: 18 Jun 2020 12:01 by Scirocco.
- Dr. Gamma
18 Jun 2020 12:06
I pull swing arms off my bikes on my lift all the time.
Pull and install motors on my lift all the time. My bench is same height as lift. Lift motor, turn, and place motor on bench!!!! Easy as hell!!!!
Place bike sideways on lift and pull front wheel and forks all the time.
EVERYTHING I do to my bikes is done on my lift. I don't work on the floor, and I have not since back in the very early 70's!!!!!
18 Jun 2020 12:10
To get all wheels off the ground you need a second and third lift.....
18 Jun 2020 12:26NOW that is a manly heavy duty lift !!!
I want the version that has removable side panels to make the lift wide enough for ATVs
- M_a_t_t
18 Jun 2020 14:32Scirocco wrote: Really, who need a ABBA lift to pull a swing arm or to pull or install a motor?
You can roll the bike around on the HF lift. I wouldn't with it raised up, but when lowered it rolls ok (cheap wheels).
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
