Bike of the Month.
  • scubaanders
  • scubaanders's Avatar
Re: Bike of the Month.
30 Nov 2025 22:04
#919471
Absolutely beautiful 😍
Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: rstnick
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
01 Dec 2025 00:24
#919472
Great work , and the result is a superb bike!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
01 Dec 2025 08:35
#919482
Nice job
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • riturbo
  • riturbo's Avatar
01 Dec 2025 14:09
#919491
Nice bike .Good save
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
01 Jan 2026 03:25 - 01 Jan 2026 03:26
#920231
To start 2026 we are heading to Germany for Joe's beautiful 1000, one of a pair in Joe's stable it's another example of Joe's great work, over to JoeHere's the story and restoration of my A1: Bought in October 2024, it had been slumbering silently in a barn for 17 years, everything was filthy with dust and gasoline residue, the usual stuff. All the brakes were seized and corroded, all the brake lines were porous, the engine was heavily oxidized, the tires, chain, and other moving parts were old and broken... with a lot of time, parts, careful polishing, and attention to detail, as well as a new paint job and a reupholstered seat, it was back on the road in March 2025.naturally it was more work than simply polishing the outside parts,...I removed and cleaned the oil pan, cleaned the oil pump strainer, adjusted valve lash, lubricated all inner engine parts like tappets, shims, cam bearings, timing chain, cylinders and pistons through the spark-plug holes, and turned it slowly, as all was lubricated by engine oil, flushed engine with new oil,....cleaned and restored all brakes and parts of them, dito try to clean the carbs, but that was hopeless. Carbs were so heavy oxidized, with totally corroded inner parts, was no rescue possible without damaging the rusted inner parts, so, I´ve rebuild another rack of VM26 carbs I`ve bought  here used...the rest" was muscle work by carefully clean and polishing engine housing and metal parts, only the rear fender was replaced, I´ve bought a new one. I left the "OZ"-wheel in place, i like them immensely! Put some new Bridgestone BT46 on it, and  left a little patina as it is.The paint job in nearly original colour was done by a friend of mine and is in perfect condition, I was happy when I got the parts back. Bike have now this season about 3000 Km´s new on the clocks, engine runs great and powerful, compression on all 4´s is about 10 to 10,5 Bar (140 psi in "old money")
Last edit: 01 Jan 2026 03:26 by Wookie58.
The following user(s) said Thank You: Mcdroid, Forrest, MFP-Joe, Stereordinary
  • sf4t7
  • sf4t7's Avatar
01 Jan 2026 05:28
#920233
Great revival Joe!  A lot of work in a short time.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • MFP-Joe
  • MFP-Joe's Avatar
01 Jan 2026 05:59 - 01 Jan 2026 06:42
#920235
Hi Scotty,
Thank you very much!
(But I'm well aware that most of the other BOTMs were restored or built much more extensively and to a much higher standard!)
I was dealing with a medium amount of work and expense here: Overhauling the forks and brakes, drivetrain, tires, inner + outer engine-cleaning ,new paint and of course some new parts like intake rubbers on head, and between carbs and air cleaner, rear fender and a full hand of all the "little" hardware, we`re almost need on a restoring ;-)
I didn't want to achieve an "over-restoration" or a "new condition" (also for cost reasons, of course), but rather to preserve a certain light "used patina" on this bike, which simply seems "honest" and authentic to me.
My philosophy on this, explained very simply:
If the hex head of a screw is still perfectly fine, and the screw isn't damaged or rusted, I see no point in re-galvanizing or replacing that screw on my bikes just because the old zinc surface is a bit darker than if it were newly galvanized...
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 01 Jan 2026 06:42 by MFP-Joe.
  • sf4t7
  • sf4t7's Avatar
01 Jan 2026 06:31
#920237
I get it, Joe.  My Z1 is also revived, not restored.  I like to say, it got patina the old fashioned way: left outside too often.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
01 Jan 2026 12:19
#920250
Well done Joe!
Blue is my favorite colour.
Love the 5 spoke wheels too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • ronnieV
  • ronnieV's Avatar
04 Jan 2026 11:39
#920321
Love it!! My soft spot. Great job!!
  • ronnieV
  • ronnieV's Avatar
04 Jan 2026 11:39
#920322
patina and balls. Lol
The following user(s) said Thank You: MFP-Joe, sf4t7
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
05 Jan 2026 00:24
#920328
Great looking bike, I really like the colour.
