Z2 750 crank (Bossie the Kaw) 12 Dec 2018 07:24 #795013
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
Been gathering paint and supplies this past year for just this time. At least the weather is cooperating though other things aren't. Bound to hit a few snagges. :pinch:
Z2 750 crank (Bossie the Kaw) 12 Dec 2018 17:30 #795049
  • SWest
  • 10 22 2014
Amazing what shows up when the color is applied.
Z2 750 crank (Bossie the Kaw) 12 Dec 2018 21:20 #795059
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
SWest wrote: Amazing what shows up when the color is applied.
...and when you blow your nose. :laugh:
I keep rubber bands on hand for flies.
:woohoo:
1982 KZ1100-A2
Z2 750 crank (Bossie the Kaw) 12 Dec 2018 21:26 #795061
  • SWest
  • 10 22 2014
Coming out blue. :lol:
Z2 750 crank (Bossie the Kaw) 13 Dec 2018 07:16 #795070
  • SWest
  • 10 22 2014
Put the 3rd and 4th coats on. Next will be wet sanding when I get the clear coat but for now I'll just look and admire it. :)
Z2 750 crank (Bossie the Kaw) 13 Dec 2018 18:48 #795113
  • SWest
  • 10 22 2014
Missed a spot. :(
Last edit: by SWest.
Z2 750 crank (Bossie the Kaw) 14 Dec 2018 18:23 #795143
  • Jimbo302
  • Jimbo302's Avatar
  • Thank you received: 7
Nice looking bike. Did I miss what happened with the crank discussion, replaced it?
Z2 750 crank (Bossie the Kaw) 14 Dec 2018 18:45 #795144
  • SWest
  • 10 22 2014
I wound up buying a 903 crank and have the 750 crank for sale. Got more compression and ponies. The 750 crank weighs the same but the shorter stroke lowered the compression. :blush:
Z2 750 crank (Bossie the Kaw) 14 Dec 2018 21:08 #795146
  • Barry1
  • Barry1's Avatar
  • Thank you received: 1
Steve, What brand of clear coat do you use?
Z2 750 crank (Bossie the Kaw) 15 Dec 2018 08:40 #795171
  • SWest
  • 10 22 2014
I've tried all of the off the shelf auto paints even the clear engine paints and was disappointed with the results. This time I'm going to use the Spray Max 2K. Some of our members recommend it and have posted beautiful work with it. This will be a test case for me. :unsure:
The following user(s) said Thank You: Barry1
Z2 750 crank (Bossie the Kaw) 15 Dec 2018 09:47 #795181
  • SWest
  • 10 22 2014
From what I've read I may have waited too long to clear coat the tank. I might have to run into town and get another can of base coat. That being the case I can fix the small blemishes before I do it. :unsure:
Z2 750 crank (Bossie the Kaw) 16 Dec 2018 07:30 #795217
  • SWest
  • 10 22 2014
Took the extra steps so I should be able to finish today. Hope it was worth it. :whistle:
