new h2
- jeffasaki
Re: new h2
01 Sep 2014 21:39
a 2 stroke would be a advantage because they make power every second stroke instead of every forth
a supercharged 2 stroke would also benifit from this as well if it was a pressureized path of induction
lets consider a seperate sump for the crankcase
with a turbo presurizing the top end with piston and barrel porting running together flawlessly without the expansion chambers of old
and a new sound for a new bike would appear
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Dr. Gamma
Re: new h2
01 Sep 2014 22:04 - 01 Sep 2014 22:05
A two stroke makes power on every revolution of its crankshaft.
Every 360 degrees of crank rotation it has a power stroke.
1986 RG500G 2 stroke terror.
Last edit: 01 Sep 2014 22:05 by Dr. Gamma.
- Dr. Gamma
Re: new h2
01 Sep 2014 22:10
How about a 1000cc V4 supercharged case reed induction motor.
With the supercharger in the center of the V. That should make a tiny lightweight package!!
- jeffasaki
Re: new h2
01 Sep 2014 22:15
i like the way you think dr gamma
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
Re: new h2
01 Sep 2014 22:18
lets build it and put it in a new chrome moly frame
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Dr. Gamma
Re: new h2
01 Sep 2014 22:25 - 01 Sep 2014 22:33
I was thinking more of a multi-tubular frame like that of a Porsche 917 made out of unobtainium.
The bike would have to be painted in that same blue that the '72 H2 750 came in!!!!
Last edit: 01 Sep 2014 22:33 by Dr. Gamma. Reason: added photo
- jeffasaki
Re: new h2
01 Sep 2014 22:39 - 01 Sep 2014 22:41
i just finished a masters in welding carbotainium
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Last edit: 01 Sep 2014 22:41 by jeffasaki.
- Tyler
Re: new h2
02 Sep 2014 06:48
Looks like the argument is mute anyway, its a supercharged 4cylinder 4-stroke.
Attachment 146-13011-kawasaki-displays-supercharged-engine-at-tokyo-motor-show_01.jpg not found
"74 Yamaha DT 400 Enduro
- jeffasaki
Re: new h2
03 Sep 2014 12:29
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Dr. Gamma
Re: new h2
03 Sep 2014 19:01
Its definitely got that wastegate popoff sound to it just like the old Porsche 956/962 did.
- jeffasaki
Re: new h2
03 Sep 2014 20:40 - 03 Sep 2014 21:08
www.motorcyclistonline.com/news/h2-kawas...irmed?src=SOC&dom=fb
THE LATEST
im gonna have a bike for sale
no it wont be the turbo or the GREEN bike but i have one i may part with and it wont be cheap it seems some one has deleted it from my signature
THE LATEST
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Last edit: 03 Sep 2014 21:08 by jeffasaki.
The following user(s) said Thank You: 74ullc
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: new h2
30 Sep 2014 12:23
