Flooring options for a motorcycle shed
- trianglelaguna
Re: Flooring options for a motorcycle shed
17 Feb 2013 15:07
dog shit beer cans a roaches...is what most folks here use
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Kidkawie
- I bleed premix
17 Feb 2013 18:09
You better put down a moisture barrier first. At least 2 layers, then use whatever floor you want. Personally, I lay down some sleepers and build a raised floor. On top of moisture barrier obviously.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Topper
17 Feb 2013 20:32
This is inside a shed with 6 foot walls. There won't be any raised floor unless I want to hunch over while I'm in there.
The shed is one of those pre-built jobs, designed to sit on skids on the ground if need be. At my site the shed sits on concrete block piers. I've added a little extra support to hold the weight of the bike.
When you say add a moisture barrier, you mean under the floor? Like between the shed floor and the ground?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Kidkawie
- I bleed premix
17 Feb 2013 21:00
Yes, thick plastic sheet directly on top of the ground. Otherwise, you'll be cleaning up rust And oxidation constantly.
1975 Z1 900
2004 KX125
2004 KX125
- KZErider
17 Feb 2013 21:02
Do you have the building anchored down really well? I'd just get a sheet of 3/4 treated, though it won't lay flat and would have to be star pattern screwed to the sub floor. Probably more permanent than what you're talking about.
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
- Lorcan
- Speed Loony
18 Feb 2013 04:06
I laid thick polythene on the shed floor then fixed 3/4" stirling board on top. Stirling board is like shavings of wood held together with resin and is moisture resistant. That was 6 years ago and no damp problems as yet. I also insulated the walls with loft insulation in between the stud work and hardboard over the top.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
