- Thank you received: 133
wobble when leaning left
- Topper
31 Mar 2012 19:01 #513236
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
wobble when leaning left was created by Topper
I'm still a relative noob when it comes to riding. I've been trying to improve my cornering and a couple of times have experienced a significant wobble if I lean particularly far left. I haven't noticed the same on the right but it could just be I'm not leaning as far over on the right.
The wobble rates about a 9.8 on my "oh sh!t-o-meter especially given that I'm leaning as far as I ever have when I experience it..
Any suggestions about what might cause this?
1979 KZ750 Twin
- Thank you received: 2829
31 Mar 2012 20:35 #513263
by 650ed
Replied by 650ed on topic wobble when leaning left
Assuming no fasteners are loose and that the rear wheel is properly aligned - I would check the following:
Tires
Steering stem bearings / adjustment
Swingarm bushings/bearings
Rear shocks
Fork oil type/freshness/level
Any of the above can cause erratic handling. Ed
Tires
Rear shocks
- Topper
31 Mar 2012 21:51 #513277
by Topper
1979 KZ750 Twin
Replied by Topper on topic wobble when leaning left
Thanks Ed. I just got new fork seals and oil. I know they're good.
I did just tighten my chain today and it's possible the rear wheel is not 100% aligned.
Any tips on making sure that's as good as it can be?
Usually I sight down the chain and eyeball it straight. I also pay attention to the notches on the side of chain adjuster, but honestly they don't seem super accurate.
1979 KZ750 Twin
- Topper
31 Mar 2012 22:30 - 31 Mar 2012 22:35 #513286
by Topper
1979 KZ750 Twin
Just found this video. He uses a caliper to align the rear wheel. And he's got a sweet vintage Kaw! :woohoo:
1979 KZ750 Twin
Last edit: 31 Mar 2012 22:35 by Topper.
31 Mar 2012 22:42 #513287
by 650ed
Some folks measure from the center of the axle to the center of the swingarm pivot bolt. If both sides are the same distance the rear wheel is properly aligned. Unfortunately, there may be bike parts in the way preventing a straight line measure of this on one or both sides. I always use the little notches on the swingarm, and so far they have proven to be accurate, but this may not be true on every bike. Ed
- JR
- Thank you received: 445
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
01 Apr 2012 01:08 #513305
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic wobble when leaning left
Have you put armor all on the tire sidewall? Maybe you got a little on the edge of the tread.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Motor Head
- Thank you received: 391
01 Apr 2012 11:01 #513353
by Motor Head
Replied by Motor Head on topic wobble when leaning left
Have a close look at your rear shocks, as 650ed suggested. Are both set to the same pre-load? You could take them off and check them for re-bound dampening, or swap side to side to see if there is a change.
- MFolks
- Thank you received: 540
01 Apr 2012 17:30 #513414
by MFolks
Replied by MFolks on topic wobble when leaning left
To expand the possible wobble causes:
I copied this from a post from Jeff Saunders (owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace if worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Wheel bearings
- Topper
01 Apr 2012 18:12 #513420
by Topper
1979 KZ750 Twin
Thanks for the advice guys. I worked on my rear wheel alignment today. Using the caliper like in the video I found didn't work for me. When I got the chain adjusters to the point where I had the same measurement on both sides, it didn't look right. On the left the chain adjuster notch was dead on the third marker (from front) and the right was at about 3 1/2. And the chain looked slightly off too. So I set them both right at the third notch, chain looked right, decided to ignore the calipers. I went for a test ride and it's definitely wobbly.
I'm due for a new rear tire and I'm going to start there. The wear indicators are all gone and the tire's got a little squareness to it (I told you I'm a noob). So I think I need to replace the tire first then try to troubleshoot after that's taken care of.
Thanks!
Thanks!
1979 KZ750 Twin
- DoubleDub
- Visitor
01 Apr 2012 20:21 #513441
by DoubleDub
Replied by DoubleDub on topic wobble when leaning left
Tire is the most likely culprit, especially considering what you just stated.
- andy9802gt
01 Apr 2012 21:50 #513467
by andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Yeah the tire will make it sketchy, ask me how I know.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
