- Thank you received: 225
A Volksaki ???
- stonemaster
- Visitor
www.motorrad-hofschaller.de/dieselfighter.html
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
stonemaster wrote: yes thats right, A Kaw frame and a 1985 Volkswagen Diesel moter
Sa'matter, OMR? Needing an English translation?
El Clicko > babelfish.yahoo.com/translate_url?doit=d...n&btnTrUrl=Translate
Then find and click on Dieselfighter.
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- stonemaster
- Visitor
- stonemaster
- Visitor
The framework for an assortment of selected components from the Kawasaki-kit was installed. Fork and brakes are from a ZX 9 R, the wheels turned in a former ZX 7 R, the rear is taken away in the swing of a ZXR 750 R. Some things had to be trimmed or even filed. Thus it was necessary to weld a Auspuffkrümmeranalge itself to put at the end of the mufflers a VN 750 which may conform closely to the rear frame is also created in the DIY. above the engine was just a dummy tank space that originally the fuel for a Suzuki TL transported 1000th The diesel is now required is found in the self-built aluminum engine spoiler _unter_ the bike. There is also the 2 batteries can be found. These are necessary because the diesel is started with the original Kawasaki starter. He is not 12 volts to spin the situation in the higher compression engine, with 24 V, however, already. With an elaborate relay system, the starter gets to run 24 volts during the rest of the electric equipment, continue to supply the usual 12V. Whether all these solutions work in practice, the diesel Fighter show now in the driving test. Thus, the findings will certainly lead to further improvements of the Diesel and Charlie Fighters ultimately help Hopefully his real dream come true to be able to more perfect. A diesel motorcycle with the three-cylinder unit injector TDI of the 3-liter Lupo. Who wants to learn more details about the origins of the diesel Fighters should read the Bauprotokoll. There are also many pictures of all phases of development.
Techno
Diesel Fighter - Volksaki GPZ 1600 TD Mk I
Motor
Four-cylinder diesel engine, turbocharger,
1570 cm ³ (from Golf II TD built in 1985),
22.5:1 compression, 51 kW / 70 hp at 4500 rpm,
133 Nm at 2150 rpm, 257g/kWh consumption,
GPZ 900 R transmission, intermediate shaft DIY,
DIY exhaust, mufflers VN 750,
RGV front radiator, drive belts and pulleys
Mechanical components, starter system GPZ 1000 RX starter
Battery 2 x 12 V = 24 V starting current
Suspension
Kawasaki GPZ 1000 RX frame, swingarm ZXR 750 R,
Fork ZX 9 R ZX 7 R wheels front 120/17 rear 200/17,
ZX 9 R brake system, rear frame DIY
Metry
Length 2230 mm, Wheelbase 1505 mm
Accessories diesel tank under the engine aluminum homebuilt,
Cusp ZX 7 Racing, fuel tank mockups Suzuki TL widened 1000,
Air scoop Fairing accessories
Headlight Mask Accessories
Attachment df35b.jpg not found
- trianglelaguna
- Thank you received: 235
and yes that bike is good for about 250,000 miles before a rebuild too!!!
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Old Man Rock
Oh great, you just gave all the youngsters Woody's... I can hear it now, "Who has a VW turbo they want top get rid of"... :blink: Porche & Testa are grinning with illusions of grandeur.... :lol: :lol: :lol:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
un shitten guber daven stoke
1976 KZ900
2003 ZX12R
2007 FZ1000
- stonemaster
- Visitor
- DoubleDub
- Visitor
