- Thank you received: 5
Engine Case Cleaning
- Marneman
Thanks.
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- stonemaster
- Visitor
- Marneman
- stonemaster
- Visitor
- kz1k
- You Cant Fix Stupid!
is this because the motor is still together? my cases are split, and was told by many members here to take them to the car wash...which i did.do not pressure wash, rinse gently after degrease (gunk), I used vinegar and water in a spray bottle, with engine together never wash with high pressure
as for the diy budget soda blaster. i have a 15 gall, decent size compressor. it took forever just to do my oil pan. i will either grit my teeth and finish the same way, or pay a machine shop to soda blast em.....joe
1978 KZ1000A2
- stonemaster
- Visitor
- kz1k
dont be sorry, from the jist i got his motor is still together.if its apart then .. i thought it was still together, sorry, pressure washing can blow out gaskets, no gasket no problem
1978 KZ1000A2
- stonemaster
- Visitor
- big mike
- stonemaster
- Visitor
- Thank you received: 2098
For consideration--...i use glass beads ( on disasembled motor)....
Many well-qualified folks recommend against any glass bead ever touching the inside of an engine or any of the internal parts.
Because getting all the glass beads removed borders on the impossible.
- z1kzonly
- Thank you received: 539
Transmissions, cases, heads.
Yes it is alot of work, but it can be done!
Of course I always thread bolts into any holes and tape oil galleys.
I always wash in hot soapy water with air agitation too.
And 3 and 4 times!
