- Thank you received: 7
The Great MKII Debate: 1979 vs. 1980
- Jack
The FI 1980 H Model wasn't sold in Canada, that was a Europe only model.The only FI was the G Model Classic, not to say someone didn't import one...
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- larrycavan
- Visitor
- 79MKII
- Love Them Kaws!
- Thank you received: 43
I remember a web site...either Klasmo or Z1 Enterprises I think....that lists the A3 as being made in Japan and the A3A as being made in the US. I always assumed the Japanese made models would be very rare...not sure??
The Kaw List:
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- TerryK
i have one on my 75 dragbike and i also have a mark11 centerpin in my big dragbike does that mean people will be upset and come after me with large caliber hand guns
Or large caliber calipers!! :laugh:
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- trianglelaguna
thanks for the offer...i can get one cheap enough just wondering if they mount....or is it just the seat that wont close ect.....
I know about the side covers being different but close...i actually have some sets of MKII side covers saved up for painting now....
larrycavan wrote:
How much different can the tanks be? I have a good ST tank and side covers if you can use them Tri
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
if a guy had a ST engine and the bottom end of a kz motor to rob the chain drive areas off,is converting the ST to chain drive as simple as removing and replacing the sprocket/shaft areas ,or is it about splitting the lower cases open?
1976 KZ900
2003 ZX12R
2007 FZ1000
- Jack
I've run shaft cases in a dragbike,got them bare so never done the shaft to chain convo. but they worked just fine. Found they were ST cases running the serial number.
MKll or ST cylinder heads are standard fare KZ with a slightly different casting which will drop on any 73-80.
Just to throw another dog on the fire, www.zedder.com shows the 1980 KZ1000 as an A4 MKll. The original A4 was the 76 KZ900 on their list.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- 79MKII
- Love Them Kaws!
Now that's just crazy! Another conflicting piece of information to mull over....my head hurts!
The Kaw List:
- larrycavan
- Visitor
Use the right trans and move the shift shaft to the other boss under the trans cover.
Some of the trans parts are slightly different as well. I used ST cases with B4 transmission when I built my engine.
Heads are heads on 1000 models. Early ones don't have air ports on exhaust side. No performance advantage to having a 79 MKII head on any KZ 900/1000. Guides in later models were cast iron vs bronze.
Castings on 1000's were better than 900's. 900's would crack near the spark plug hole.
A4 www.bikebandit.com/houseofmotorcycles/19...-us/o/m3934#sch83527
ST
www.bikebandit.com/houseofmotorcycles/19...-us/o/m3183#sch85030
As far as 79 MKii vs 80 A4, anything black is always faster than the same model in red. It's a proven scientific fact that black paint has less wind resistance than red
