Making a key by the code number.
  • LoganKX
  • LoganKX's Avatar
Re: Making a key by the code number.
07 Nov 2019 03:38
#813662
Hi mate, I have a 82 kz750gt I have to unfortunately part ways with and someone is interested to buy it but I have misplaced the key over time. Can you help me please!?
Cheers
Logan
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
07 Nov 2019 06:01
#813666
LoganKX wrote: Hi mate, I have a 82 kz750gt I have to unfortunately part ways with and someone is interested to buy it but I have misplaced the key over time. Can you help me please!?
Cheers
Logan
You should contact rstnick direct as he may not check in here and see your post
  • martin_csr
  • martin_csr's Avatar
08 Nov 2019 05:05 - 08 Nov 2019 08:55
#813704
A good locksmith should be able to make a key from the code. Also, there are usually keys available on eebbaayy >> some sellers can cut a key using the code which can be found on the ignition switch. The same code should also be on the seat lock & helmet lock, but removing the ignition switch might be the only feasible way to get the code. keys cut >> example EB item # 333089344956
I had a key made for my 81 KZ650-CSR using an Ilco KA14 X103 blank >> it's almost identical to the Kawasaki keys in the pic. Your key may be different.
Last edit: 08 Nov 2019 08:55 by martin_csr.
  • rstnick
  • rstnick's Avatar Topic Author
  • Premium Member
  • Premium Member
13 Feb 2022 11:48 - 13 Feb 2022 11:50
#862256
I am still making keys by the key code number for those in need.
Rob
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 13 Feb 2022 11:50 by rstnick.
The following user(s) said Thank You: ThatGPzGuy, TexasKZ
  • Kawasakik1e
  • Kawasakik1e's Avatar
27 Apr 2024 19:48 - 27 Apr 2024 19:49
#898178
Hanging some difficulty figuring out how to PM on this forum....
 can you reach out to me? I need keys for my daughters '77 KZ400.
Key code is 7 9 0
Thanks......!!
The Collection-all insured, plated and ridden.
'79 KZ650 EFI/Turbo Project
'76 KZ900 "Workin' Man"
'00 ZRX1100 The Beast
'09 H-D XR1200 "XR8ted"
Last edit: 27 Apr 2024 19:49 by Kawasakik1e.
  • TexasKZ
  • TexasKZ's Avatar
27 Apr 2024 19:59
#898180
Key code is 7 9 0
Thanks......!!
PM system is broken.
The following user(s) said Thank You: Kawasakik1e
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
28 Apr 2024 00:34
#898182
Rob are you happy for me to share you email with this member looking for keys ?
  • Kawasakik1e
28 Apr 2024 07:36 - 28 Apr 2024 11:30
#898185
Thank You!
Last edit: 28 Apr 2024 11:30 by Kawasakik1e. Reason: Deleted my personal email address
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
28 Apr 2024 07:58
#898187
... or if you could forward my email to him? I would greatly appreciate it.
Im at:  2000zrex@gmail.com
Thank You!
No need now you have posted it, the offer was to keep your contact details out of the public domain !!
  • Kawasakik1e
28 Apr 2024 10:54 - 28 Apr 2024 11:14
#898195
Not worried about my email being public; figured I might speed up the process .... if you would be kind enough to email him directly; he might see an email pop up on his phone faster than him getting around to logging onto this site and seeing a notification..... as he is running a business cutting keys, I don't think he'd mind the help. I might be wrong.
EDIT:  Looks like Rob(Rstnick) had his email posted a bit deeper in this thread.
it is: rstnick@hotmail.com
thanks for any help you can provide!
Last edit: 28 Apr 2024 11:14 by Kawasakik1e.
