Making a key by the code number.
- Tony
Author
Re: Making a key by the code number.
04 Dec 2010 17:01
This is a great thread and lost keys are an on going problem. I don't know about everyone else, but I think this thread should be stickied. Since I've got the little button that allows me to make this a sticky, I'm going to go ahead and do just that.
- gmannz1
20 Mar 2011 13:55
I'm looking for a key for a 1980 KZ750 twin. I found the number on the ignition and it matches the seat lock. I bought a key with the same number, but its labeled GPz, it fits the lock (correct blank), but doesn't open the lock. I talked to a local locksmith who had the cutting code for 1984 and later for my key code. He thought they were probably the same, but I'm not so sure. Has anybody run into issues where the same code number has been used pre-1984 and post-1984, but the keys are different? Or can you help me find a 1980 version of key code Z5365.
Thanks
Thanks
1975 Z1B
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
- saxjonz
- KawboyZ
21 Mar 2011 23:55
Well, I had a key cut at the locksmith from the number off of the ignition. I don't know if that helps at all but hey if a key is what you need then this is what you should do.
79 LTD B3
- purls
01 Apr 2011 02:06
This is great info. Thanks.
1983 KZ750 Spectre
1978 KZ650B2A
1978 KZ650B2A
- RetroRiceRocketRider
01 Apr 2011 10:55
If you have the earlier (4 cut) key, check with an older Kawi dealership. Ma Kaw offered pre-cut keys by the lock number back in the 70's, and if they haven't round-filled them some of the older dealerships still might have some.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- mtbspeedfreak
01 Apr 2011 17:20
There are a few retailers out there with OEM pre-cut keys in stock. I paid 15 bucks for my cherry black plastic OEM key. Just match the code and you're set.
Do a Google search for Kawasaki pre-cut keys. I'll send out a few links at a later point when I'm not at work.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
02 Apr 2011 04:26
Here you go:
www.johnnysvintagemotorcycle.com/
Also, give eBay a shot too. Like I said, I just got a "brand new" OEM key. Black plastic with the Kawasaki shield on it and everything. Cherry. Very happy. The $15 was well spent in my book.
2000 ZRX 1100
- rstnick
02 Apr 2011 20:31gmannz1 wrote: I'm looking for a key for a 1980 KZ750 twin. I found the number on the ignition and it matches the seat lock. I bought a key with the same number, but its labeled GPz, it fits the lock (correct blank), but doesn't open the lock. I talked to a local locksmith who had the cutting code for 1984 and later for my key code. He thought they were probably the same, but I'm not so sure. Has anybody run into issues where the same code number has been used pre-1984 and post-1984, but the keys are different? Or can you help me find a 1980 version of key code Z5365.
Thanks
The Z**** series does have two sets of codes.
IIRC they're labeled Z****(Older) and Z****(Newer) in the program.
Not sure off hand what year the change over was.
Can you take a picture of your key and post it so I can read the bittings and determine if it matches the Old or New series?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: Mullineaux
- KZShafted
16 May 2011 13:56
Thanks for the post. I broke my only key in the tank lock to my 95 Police1000 yesterday and this info was very useful. A local locksmith was able to help make a new one and it was a whopping fifteen bucks. As luck would have it I was able to get the broken piece out without causing damage.
1980 KZ1000 Shaft
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
- Kawasaki_Mike
- 1980 Kawasaki 750 LTD
17 Jun 2011 19:04
I sent a message to the OP (rstnick) regarding getting some keys made up for my 1980 Kawasaki 750 LTD. Does anyone know if he is still around and can still do this? If not, can someone else point me in the right direction? Thanks all.
- ravenz07
06 Jul 2011 13:29
I would also like to know the answer to the same question. I have the same bike and have the key code. Anyone here can do it?
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
- rstnick
21 Aug 2011 00:22
Send me an email at rstnick@hotmail.com as I don't see posts here often enough.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: sig, Kawasakik1e
