lost keys
- dwilliams2385
- to each there own as long as u leave me alone!!!!!
27 Nov 2010 08:34 #414395
by dwilliams2385
1979 kz650 c3
lost keys was created by dwilliams2385
please help ive lost my keys would anybody have a z5605 number key im laid off of work and have five kids and a ole lady to support so a highdollar locksmith is outa the queation any help will be greatly appreciated
thanks again Z5605 is the key number thank god i wrote it down in the owners manual
dave
dwilliams2385@aol.com
dave
1979 kz650 c3
- Thank you received: 2098
27 Nov 2010 08:57 #414396
by Patton
Replied by Patton on topic lost keys
Already checked to see if maybe left in the seat lock?
Hope it might be found soon.
27 Nov 2010 09:17 - 27 Nov 2010 09:19 #414397
by Patton
Could check with KZr member rstnick who is a Locksmith and can cut keys by the code #.
Cost for a pair of keys might be less than $15 (perhaps $10 + $3 shipping).
Last edit: 27 Nov 2010 09:19 by Patton.
- hydrolazer
- Thank you received: 3
30 Nov 2010 14:13 #414847
by hydrolazer
\'79 kaw 1000 ltd
Replied by hydrolazer on topic lost keys
lock jock made me one for a dollar. the girl said give me number and not the key. i was truly amazed when i put it into the bike and it worked
\'79 kaw 1000 ltd
- jeffasaki
- Thank you received: 44
30 Nov 2010 16:03 #414860
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic lost keys
Just over ride it with a simple on off switch
All you need is a normally open one way toggle switch
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Injected
- Thank you received: 538
30 Nov 2010 17:26 #414866
by Injected
Replied by Injected on topic lost keys
I seem to remember that any Kawasaki key from that era works on the ignition and the gas cap, but the seat lock keys were different? or maybe I got that the wrong way around?
I think you could also jam a thin bladed screwdriver in there and start it also - a lot of them were stolen that way... I have seen a lot of ignition switches from that era scratched in the same way from doing such a thing...
The bypass toggle also works... right off the battery like a drag racer - the $2 option.
- JMKZHI
- Thank you received: 48
02 Dec 2010 07:22 - 03 Dec 2010 03:56 #415032
by JMKZHI
Replied by JMKZHI on topic lost keys
All 3 are coded the same: ignition switch, seat lock, & helmet lock, so you need the correct key. The code is located on the underside of them. Without a spare key, you'd probably have to go to the dealer or a locksmith. If you have a spare key, any hardware store should be able to cut one. I got mine from the HomeDepot - ilco KA14 X103.
The fuel cap is a simple device - you can use any thin, flat key to open it. Whatever you use has to be thin enough to fit thru the opening & reach down a good half inch or so. Some folks say you can use a screwdriver, but it would have to have a long flat blade on it. I tried a couple of small screwdrivers, but even they were too big to fit into the opening - they didn't reach down far enough. Unless you don't mind damaging stuff.
Edit: the info is in regards to the 80s models. The earlier bikes might be different, especially the fuel cap lock - maybe you can use any old screw driver on those.
Last edit: 03 Dec 2010 03:56 by JMKZHI.
- Wile
- Kawasaki is Japanese for money pit
03 Dec 2010 03:54 #415120
by Wile
98% of all Harleys ever sold are still on the road. The other 2% made it home.
“I'd rather be riding my motorcycle thinking about God than sitting in church thinking about my motorcycleâ€
"Only a biker knows why a dog sticks his head out of a car window"
Replied by Wile on topic lost keys
- dwilliams2385
08 Dec 2010 15:13 #415967
by dwilliams2385
