- Thank you received: 540
Z1-KZ Slider Clutch Info
- z1kzonly
24 Nov 2010 15:59 #414064
by z1kzonly
Z1-KZ Slider Clutch Info was created by z1kzonly
Looking for a used slider clutch for a KZ900 drag bike engine.
What is the going price?
What can I expect?
Not in any hurry, I can wait!
Don't want to spend $$ on new one.
Any opinions?
Thanks.
What can I expect?
Any opinions?
Thanks.
- timebomb33
- Thank you received: 10
24 Nov 2010 17:14 #414091
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Z1-KZ Slider Clutch Info
keep an eye out on dragbike.coms classified section, they come up from time to time
- racer54
- Thank you received: 114
24 Nov 2010 17:20 #414093
by racer54
Replied by racer54 on topic Z1-KZ Slider Clutch Info
Be careful when looking at one. Look at the hat to see what shape it's in. Sometimes a bolt, etc. gets loose and tears them up. Check to be sure the bolts that hold the hat on are in good shape. Seems to be a weak point with them. I'm no expert on them by any means but these are just some things I have read about or seen. You know any weak points or things in particular to look for Timebomb?
- timebomb33
24 Nov 2010 17:23 #414096
by timebomb33
i try to stay away from sliders my self usally they are being sold for a reason this would be one item if i was looking for that i'd probably buy new. save your self a bunch of grief and expense in the long run.
- Jack
- Thank you received: 7
24 Nov 2010 18:05 #414101
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic Z1-KZ Slider Clutch Info
I've seen them for $500-750 -like Tim posted keep an eye on dragbike.com classifieds.Older sliders have 6 mm. studs and need to be updated to 8mm.- good way to identify them is the cover has an oil filler cap threaded into it as an inspection port.The 6mm. studs inevitably pull out or break.I broke 2 and as posted it did make a mess of the hat and some of the weights.
Take a good look at the inner basket and the inside of the slider basket for wear. Good idea to check the threads on the basket & the small allen bolts that secure the hat to the slider basket.Check the outside of the slider basket for wear marks- not everyone remembers to clearance the cases - if it wobbles enough to hit the cases you'll see the "machining"
I bought my slider very gently used and knew the bike and the shop it came from originally.If you buy a slider get the shim kit from MTC to set the air gap properly.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- z1kzonly
24 Nov 2010 19:06 #414105
by z1kzonly
Replied by z1kzonly on topic Z1-KZ Slider Clutch Info
Thanks, great tips! Will watch for awhile.
Al Fletcher from Lancaster advised me on this also!
I just got a bad back,and neck, and slider is the way to go!
Thanks!
Thanks!
- kawi810
25 Nov 2010 06:42 #414171
by kawi810
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
Replied by kawi810 on topic Z1-KZ Slider Clutch Info
i seen one on tampa fl craigslist for $400. he has other z1/kz parts for sale.
