Should I buy it?
- Exodus5
- MFolks
- Thank you received: 540
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
- stonemaster
- Visitor
if it needs what u think it does it probably has a few hidden surprises, happened to me once, i wouldnt go much more than what u said, I mean ur lookin at that for tires and repairs on what is obvious, besides right now ITS A BUYERS MARKETJust went today to look at a 1981 KZ1000 this local kid has. 24K miles, in acceptable shape. Repainted at some point (non-original) and had a little rust on the exhaust pipe and some on the frame but not too bad. Rear air shocks did not give at all. Not sure if one or both are locked or if it's just too much air in the shocks. The kid tried to fix a gas leak and ended up changing orings in the bowls. Fixed the leak but didn't sync the carbs. Also appears to be leaking from the head gaskets. Bike idled after warming up at 2000rpm. Needs tires also. He was asking $1300, but I'm thinking I'm looking at about $500-600 for all the things I need to do. I'm thinking of offering $600. Is the bike worth more than that? I'm new to these and I expected to have to do a little but $1300 seems to be the going price in "good" condition and this one needs several things.
