- Thank you received: 1616
How much weight can be lost?
- loudhvx
25 Oct 2010 09:29 #408954
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic How much weight can be lost?
My 550 was claimed to be 440lbs totally dry, by Kawasaki.
I removed the fairing, gauges, a bunch of wiring, small relays etc and associated mounting tabs, turn signals, little frame tabs, tail light sub frame, grab rail, front fender replaced with plastic, emissions contraption, toolbox, chain guard (plastic), replaced headlight assembly with lighter assembly. All in all, probably about 20 pounds or so.
But then I added a fork brace and steering damper.
The bike weighed in at 430 lbs with fully loaded with fluids.
Removing the starter would make some difference.
This was on the yellow bike.
I haven't weighed the red bike yet, but I expect that to come in much lighter (no starter and no batt).
1981 KZ550 D1 gpz.
Other links.
- porchev914
- Thank you received: 19
25 Oct 2010 11:33 - 25 Oct 2010 11:36 #408973
by porchev914
FRANKEN Z!
Replied by porchev914 on topic How much weight can be lost?
Ditch the heavy stock rear swingarm and suspension, ditch the heavy stock front suspension, swap in BST carbon wheels and remake your frame from some light gauge ChroMo tubing....even then, you're still sitting on a boat anchor of an engine (not as heavy as a 900/1000 but still)...not much you can do about that for a street bike. How far are you willing to go, and how stock do you want the bike to look?
Depending on how well fed you are, it might be cheaper to loose some of your own weight before you attack your bike. I know that would certainly be the case in my circumstance :laugh:
FRANKEN Z!
Last edit: 25 Oct 2010 11:36 by porchev914.
- scumbag
- Lewd, Screwed, and Tattooed
25 Oct 2010 12:42 #408987
by scumbag
sept.1976 kz650
1980 kz650
Replied by scumbag on topic How much weight can be lost?
531blackbanshee wrote:
It is looking a bit different. Same idea though.
nice to see you checking back in scumbag.does the 650 look the same as the last time you visited?
sept.1976 kz650
1980 kz650
- mjg15
25 Oct 2010 13:46 #408997
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic How much weight can be lost?
Looks like you've already gotten rid of the easy weight loss items.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- scumbag
25 Oct 2010 20:35 #409082
by scumbag
sept.1976 kz650
1980 kz650
mjg15 wrote:
I wouldn't say it was spectacularly easy.
sept.1976 kz650
1980 kz650
- larrycavan
- Visitor
25 Oct 2010 20:49 #409088
by larrycavan
Replied by larrycavan on topic How much weight can be lost?
650ed wrote:
:laugh: :woohoo: :silly:
I shaved about 175 pounds off mine when I divorced my first wife. :laugh:
- steell
26 Oct 2010 09:44 #409170
by steell
Replied by steell on topic How much weight can be lost?
650ed wrote:
So true, and it doesn't even need an alternator. And I bet the rider runs it in heavy rain, sits at red lights, drives it at partial throttle and low speeds in traffic, etc. etc. Oh no, what's that you say, it's a single purpose race bike, I never would have guessed. [/quote]
Not only is it running no airbox, it's using no filters at all, just straight velocity stacks. So if your point was to compare it to individual (pod) filters, it's apples to oranges.
TexasKZ wrote:
HMMMM.... A road race bike that must make big horsepower over a fairly wide rpm range and that must deal with headwind, tail wind, side wind, butt wind, and no wind, does not seem to be using the stock air box. OH, MY! :ohmy:
