What to do......
- 31goodtymes31
Re: What to do......
22 Nov 2010 21:48
So now that winter has hit with a vengeance up here, I haven't had the time ti really start tearing the bike apart. I'm going to get the panels and the fenders painted. I'm also thinking about buying a whack of stuff from Z1 enterprise to have ready for the spring. I want to rewire the bike and although I'm not 100% sure how to do it, I'm pretty confident that I can figure it out. I was thinking about getting new pistons (1075 vs 1200 big bore ape kit?) I was thinking about also getting a new dyna s ignition kit and a new acewell gauge. I was just wondering how I would be able to use the tach function on the new gauge if the tach on the bike is mechanically driven? I'm sure that it is possible but I'm not sure how to do it.
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- WPBill
24 Nov 2010 07:02 - 24 Nov 2010 07:10
You absolutely sure you need a second disk? Remember that adding 1 lb of unsprung rotating mass is like adding 20lbs (IIRC) to center mass. Plus, carrying that extra weight is going to make your front suspension less responsive.
You can spritz out your single disk setup fairly well. Stage it out as finances become available.
Good pads and stainless steel brake lines from Z1Enterprises.
Full floater OEM diameter rotor, also from Z1E.
Twin piston Nissin caliper from either ZPower Aus.
Or, if you really want to go top line, Z1E can get you a full kit from PMC Japan that is centered around a Lockheed twin piston caliper.
Yeah, the photo shows a dual disk but PMC also sells a single disk kit. Also, since the last time I visited the PMC site, it appears they have a 4-piston kit as well. Cool!
There's also an outfit in UK that sells a 6-piston cailper bolt on kit. PreTech?
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
Last edit: 24 Nov 2010 07:10 by WPBill.
- z1kzonly
24 Nov 2010 07:35
WPBill wrote:
Boy is that a sweet brake kit!
I bet that dual kit cost's dual thousands of dollars!
- lemo32
- The Price of Cool aint cheap
24 Nov 2010 14:44
This reminds me of my first kz, that thing rode great until i got home. Everybody told me to stay away from it, but something bit me. I built a garage, rebuilt the bike, learned more than i thought i ever could.
1979 kz 1000 06 katana 750
- WPBill
24 Nov 2010 18:35 - 24 Nov 2010 18:36
z1kzonly wrote:
Using today's yen rate, about $1500 out-the-door at PMC in Japan. Take off about $100 is you don't want the master cylinder. Single cylinder kit is about 400 bucks less.
You can get them through Z1 Enterprises, although I don't know how much more S&H&C will cost you.
PMC also offers AP Racing 4-piston caliper kits, but I like the looks of the APR/Lockheed twin piston caliper better.
Last edit: 24 Nov 2010 18:36 by WPBill.
- 31goodtymes31
24 Nov 2010 19:10
I took a look at the z1enterprise site and I couldn't find it. Is that a special order type idea? Those brakes look sweet though. Thanks for the tip.
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- 31goodtymes31
24 Nov 2010 19:13
there are so many disbelievers in this bike. They can't understand why I want to spend money on this thing. They can't even believe that I spent the money on a bike that old. It's going to be fun proving them wrong....
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- hocbj23
24 Nov 2010 19:26
Before u start spending megabucks on upgrades,spend a few bucks and get a factory service manual.Then carefully go thru the bike and do all the routine maintenance that may or may not have been done in the past 33 years.drain the oil,new filter,new plugs and wires,set the time,clean the carbs,clean the carbs,clean the carbs,.Got the picture. The bike as is and properly tuned will have all the useable horsepower and handling u could ever possibly use given todays driving conditions. If after all that u still feel the need for speed,proceed with caution and deliberation.The bike u save intact today will be a genuine collectors piece tomorrow.BJ
- WPBill
24 Nov 2010 21:37
31goodtymes31 wrote:
Yup. You can get the full floater rotor directly from Z1E, but the sexy PMC stuff you call Z1E and have them procure from PMC for you.
- 31goodtymes31
25 Nov 2010 14:35
Yeah I got the carbs done as soon as I got the bike. THey were pretty gunked up. I have the manual and I have done the basic maintenance stuff and had it running up until the weather got too cold to ride. So so far I've got the basic stuff covered. I just want this thing to be a one of a kind bike... with a few modern upgrades.
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
- TerryK
25 Nov 2010 15:07
While it's a great passion with many of us (I have the same bike as you) and it a ton of fun restoring or modifying these old classics, your KZ will NEVER be on par with any modern sport bike, or even standard bike for that matter. Old technology, steel frame, heavy weight among many other things will always hold it back. If you keep this in mind, you will enjoy the bike for its classic looks, sounds and even it's quirks.
Enjoy!!
Enjoy!!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- 31goodtymes31
28 Nov 2010 12:34
Does any one know where I can get an extended swingarm from? I was thinking about a 6 inch over?
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
