- Thank you received: 1
Is 139DB Overkill for a motorcycle horn?
- 550A2
- keep the shiny side up
11 Oct 2010 08:56 #405954
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Is 139DB Overkill for a motorcycle horn? was created by 550A2
I found this, and I felt the need to post! Check it out....I think i might get one!
www.aerostich.com/ear-cannon-air-horn.html
- jayw704
11 Oct 2010 09:22 #405956
by jayw704
1978 KZ1000
Go Loud and go fast or dont go at all!!!
Replied by jayw704 on topic Is 139DB Overkill for a motorcycle horn?
very cool I wonder, for those of us that are electricaly savy, if you really need the wiring harness?
1978 KZ1000
- PLUMMEN
- Thank you received: 104
11 Oct 2010 09:45 - 11 Oct 2010 09:53 #405963
by PLUMMEN
Replied by PLUMMEN on topic Is 139DB Overkill for a motorcycle horn?
maybe you canfind one of these cheap on ebay to mount it on! :woohoo: oopsies,forgot the picture! :laugh:
Last edit: 11 Oct 2010 09:53 by PLUMMEN.
- KZ250LTD
- Thank you received: 16
11 Oct 2010 11:56 - 13 Feb 2012 19:25 #405982
by KZ250LTD
Last edit: 13 Feb 2012 19:25 by KZ250LTD.
- PLUMMEN
11 Oct 2010 12:00 #405984
by PLUMMEN
noi was talking about buying a locomotive to mount the horn on! :laugh:
- PLUMMEN
11 Oct 2010 12:02 #405987
by PLUMMEN
- Thank you received: 2829
11 Oct 2010 16:25 #406031
by 650ed
Replied by 650ed on topic Is 139DB Overkill for a motorcycle horn?
Those are girlie horns! Here are manly horns (be sure to listen to the test at the end of the link:
Manly Horns
Now if I could only figure out how to mount them on my bike :laugh:
Manly Horns
- taildragger1197
- Thank you received: 17
11 Oct 2010 18:40 #406048
by taildragger1197
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
Replied by taildragger1197 on topic Is 139DB Overkill for a motorcycle horn?
That's not a horn.
THIS
is a horn.
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- RonKZ650
- Thank you received: 240
11 Oct 2010 18:58 - 11 Oct 2010 19:00 #406050
by RonKZ650
Replied by RonKZ650 on topic Is 139DB Overkill for a motorcycle horn?
Really horns are of little value except if some slow speed thing like a Walmart parking lot and someone is backing out and doesn't see you. They actually are a nuisance and I'd rather they were not available to people most the time. A horn to me is the same as flipping someone off most the time. I read the various newsgroups and see the guys that say "I was riding and saw a car that was not going to stop for a stop sign as I was approaching an intersection. I laid on the horn, but they still did not stop and we had the big TBONE." Well you waste time fumbling with your thumb instead of using evasive action? idiot. Sorry, but ride to stay alive, don't use your thumb.
Last edit: 11 Oct 2010 19:00 by RonKZ650.
11 Oct 2010 19:14 #406051
by 650ed
Ron, I agree with you, but I think the "horn" in taildraggers link might prove to be the exception to the rule. Considering that it's 12 feet long, 6 feet tall, and weighs in at nearly 3 tons even if the other driver didn't hear it or see it the sheer mass of the thing might offer some protection if you could somehow place it between the bike and the oncoming car. :laugh:
- Thank you received: 2098
11 Oct 2010 19:35 - 11 Oct 2010 19:37 #406052
by Patton
Replied by Patton on topic Is 139DB Overkill for a motorcycle horn?
Disembarking at Port Canaveral
Last edit: 11 Oct 2010 19:37 by Patton.
- WPBill
- Thank you received: 12
11 Oct 2010 19:39 - 11 Oct 2010 19:42 #406054
by WPBill
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
Replied by WPBill on topic Is 139DB Overkill for a motorcycle horn?
You can get the same horn at your local Harbor Freight, where it is called a Wolo Bad Boy. The horn does need a full 12V to function properly. Depending on how your bike's OEM setup is, you may need to run a separate power circuit instead of just "plug-and-play." Try the horn out connected to the exisitng horn power wires and then directly to the battery. If there is a difference, then you need to run a separate 12V circuit and use a horn relay.
The horn relays included with these horns are crap. They are known to fail quite easily, and in the ON position at that. If you have to use the relay, go to Radio Shack and pick up a heavy duty automotive horn relay, they are about 3 bucks or so, IIRC.
For the money involved, these WOLOs are well worth it. Especially the first time some brain dead cellphone texting idiot tries to occupy the same space as you are on a freeway.
Last edit: 11 Oct 2010 19:42 by WPBill.
