Anyone tried BugEyes?
10 Oct 2010 07:34 #405640 by seanof30306
Anyone tried BugEyes? was created by seanof30306
www.bugeyes.com/
I have superbike bars on my bike, so all I see in the mirrors are my shoulders.
I got a set of mirror extenders, which do help, but they make the bike look really wimpy, and the mirrors still aren't great.
I'm either going to go to a wider set of bars with the same (or close to the same) rise and pullback as the superbike bars, then put mirrors with integrated turn signals on them, or I'm going with the BugEyes and eliminate the mirrors altogether.
So far, I haven't been able to find sny bars that fit the criteria. The superbike bars are 29" wide, with a 2.5" rise, a 4.75" pullback, and a center width of 4.5". I figure I'll need at least 32" wide, if not 33" to solve the mirror problem.
The BugEyes were cheap enough that I went ahead and bought them to try. If I don't like them, I'm only out 25 bucks.
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • seanbarney41
  • '79 kz1000 LTD '75 Honda CB750
10 Oct 2010 11:21 #405679 by seanbarney41
Replied by seanbarney41 on topic Anyone tried BugEyes?
Thought about bar end mirrors? Bugeyes seem kinda trick but what about the man? Does your state have and enforce a rearview mirror requirement?
10 Oct 2010 11:33 #405681 by otakar
Replied by otakar on topic Anyone tried BugEyes?
Those are COOL. I might have to try some. They are cheep enough.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
10 Oct 2010 12:20 #405694 by seanof30306
Replied by seanof30306 on topic Anyone tried BugEyes?
Yeah, I've looked at 'em, but I don't like the way they look, with my luck (and accident-proneness) I'm sure I'd tear them off with alarming regularity, and having ridden a bike with them, I didn't like having to look that far down to see them.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • seanbarney41
10 Oct 2010 12:24 #405695 by seanbarney41
Yeah, I sure am clumsy too. That's a good point. I had been wanting 'em because I dig how they look. Hadn't even thought about that aspect.
10 Oct 2010 13:17 #405704 by TexasKZ
Replied by TexasKZ on topic Anyone tried BugEyes?
Seems like the bug-eyes would introduce turbulence and noise that none of us needs. I have a set of CRG bar-ends on my ZRX and like them just fine.
10 Oct 2010 15:09 #405750 by seanof30306
Maybe. We'll see when they get here.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
10 Oct 2010 15:59 - 10 Oct 2010 16:00 #405758 by otakar
No eBay APP ID and/or Cert ID defined in Kunena configurationseanof30306 wrote:
www.bugeyes.com/
I had the same problem with my mirrors when I installed my bars. Until I bought a set of these mirrors. They mount in the conventional mounts that you already have and they work fantastic. I was shocked how well they worked.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 Oct 2010 16:00 by otakar.
10 Oct 2010 16:26 - 10 Oct 2010 16:32 #405764 by seanof30306
No eBay APP ID and/or Cert ID defined in Kunena configurationotakar wrote:
seanof30306 wrote:
www.bugeyes.com/
I'd be curious to know what the measurements are. Do you know what a plumb bob is?
EDIT: Oh, wait, I just saw the measurements in the auction. I'll go measure my mirrors.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 10 Oct 2010 16:32 by seanof30306.
10 Oct 2010 16:57 - 10 Oct 2010 16:58 #405769 by seanof30306
Well, this is odd. On that auction, they had a pic with measurements. The critical one to me is the width of the mirror, measuring from the stem to the outside edge of the mirror. On this mirror, that measurement is listed as 8.26"
When I went and measured my standard square mirrors though, that measurement was 9 7/8". Measuring to the edge of the extenders, it's 11 1/2", and I could use more!
Now I'm big (6'5", 280lb), and maybe that's the difference.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 10 Oct 2010 16:58 by seanof30306.
10 Oct 2010 17:02 #405770 by otakar
With my standard mirrors I could not see anything either. but with these I can.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
10 Oct 2010 19:06 #405823 by dejavoodo41
Replied by dejavoodo41 on topic Anyone tried BugEyes?
This seems to be cool I don't know how it would work but it's a cool concept. I've also seen a few bikes that mount a small backup camera on the rear of the bike with the screen mounted with the guages.
www.reevu.com/motorsports.asp
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
